  • Replies 51
Here's the one I submitted over 4 months ago.... Didn't get much feedback at all so I gave up..
Performance Enhacenments to come (time permitting) :
http://brf.homelinux.com/images/flyer.pdf
so b-man, the battle is on. do we need a poll, or are there other good alternatives to include first.
Dino, yours was great, but the url was wrong so it cant be accepted. And Ben, I like that fact that yours had headlights and taillights at the same time. very witty
These Weapons of Mass Destruction cannot be displayed
The weapons you are looking for are currently unavailable. The country might be experiencing technical difficulties, or you may need to adjust your weapons inspectors mandate.
Please try the following:
Click the Regime change button, or try again later.
If you are George Bush and typed the country's name in the address bar, make sure that it is spelled correctly. (IRAQ).
To check your weapons inspector settings, click the UN menu, and then click Weapons Inspector Options. On the Security Council tab, click Consensus. The settings should match those provided by your government or NATO.
If the Security Council has enabled it, The United States of America can examine your country and automatically discover Weapons of Mass Destruction.
If you would like to use the CIA to try and discover them,
click Detect weapons
Some countries require 128 thousand troops to liberate them. Click the Panic menu and then click About US foreign policy to determine what regime they will install.
If you are an Old European Country trying to protect your interests, make sure your options are left wide open as long as possible. Click the Tools menu, and then click on League of Nations. On the Advanced tab, scroll to the Head in the Sand section and check settings for your exports to Iraq.
Click the Bomb button if you are Donald Rumsfeld.
Cannot find weapons or CIA Error
Iraqi Explorer
BTW, when is this thread moving to wasteland?
I didn't feel like going to bed tonight so I decided to make a flyer, not sure if it tops the previous effort though...
I was thinking of using an R34 but couldn't find a pic I could use. I can change the text and pic if need be. This has been optimised in order to be able to atach it, I can provide a higher quality one if needed.
Let me know what you think.
Matt
OK,
So we have some good ideas... what we need is to set wome criteria... try thinking about what the club is about... what we do and also perhaps include some sponsors of the club...
But I do like B-mans and Funkbrothers!
Lets se if we can bring this thread back from the wasteland... now... how do I ban Duncan???
Dan.
  • 1 month later...
Bumpity bump bump bump -
Oh and one more B U M P
because this has been hanging around like a bad smell for WAY TO LONG.
Someone make a damn decision ! I don't care who's banner wins - I'll withdraw my entry if it makes it easier... Damn it.
We as a club should - sorry, NEED to have these flyers so we can get more members.
FFS -
PS - We don't really need a club meeting to resolve this do we ??? What wrong with using the forums as a medium to get this decision made ??
  • 3 weeks later...
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
