Item:
(Complete Motor and Add-ons)
1992 R32 RB20
HKS2530
550cc Injectors
Nismo Fuel Reg
Microtech lt8
RB20 Gearbox
R32 Crossmember
R32 Gearbox Mount
Drive Shaft
etc
Gold Coast
Item Condition:
78000 on engine
Runs well
Reason for Selling:
Upgrading to a 25
Price and Payment Conditions:
$3500
cash
transfer
Extra Info:
Engine will remain in car until just after the Nissan Cruise at the end of January so if you want to see, hear and be taken for a drive in the car you have just under a month. After that cruise engine will be taken out of car, cleaned and everything checked.
Contact Details:
[email protected]
PM
Edited by boostin_180
https://www.sau.com.au/forums/topic/99855-rb20-motorboxcomputer/
Beware of this seller, he is not to be trusted. He has owed me money for the past 10 months, was ordered by a court to pay to me the money 4 months ago after i sued him, and i'm still waiting to receive all of my money.
right, well when u get the cash.. can u get the engine 2? n do a swap 4 me n ill give a bit of money :lol: :P .. thanks for the heads up mate. Hope everything works out "for the both of u????"
have u though that maybe im selling cause i dont have any money to pay u there 176 dollars??
Didnt think so... there is nothing dodgy about the sale u can come and watch me take the engine out of the car if your that paranoid.
Im no mod on this site guys, but for the sake of the guy who started this thread's sale.. maybe take it 2 PM.. we've established that someone has made some bad errors in the past. So lets leave it their n proceed with warning. :P
Steve.
Riiight, so you can order a new bodykit but you can't give me $176? You got paid out for 4 weeks of holiday pay but couldn't spare $176 that you said you'd give me 2 months ago?
Once again u are wrong. I havent ordered a kit.. i was going to.. but because of situations that occured i havent ordered shit. The money i got from my holiday pay was gone before i even got a chance to touch it due to stuff that happened with my family life so back the f**k up. Get ur facts straight before you go make alegations.
Don't you even start on what you've been going through, you have no idea of the greiving i was going through when you made me drag you through the courts.
I'm not going to say anything else in this thread. If you want me to allow you freedom to sell your goods then pay me my god damn money.
Thank u
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
