Hey Guys I have:
gtr turbos: excellent condition, that have never been boosted with minimal shaft play. They were put new on my car in japan off an r33. $500
Genuine Nismo Front pipe: used good condition. $400 SOLD
Genuine HKS dumps: Brand new in box never used, with all gaskets fittings etc. $600 SOLD
All Inlet pipes and cross overs for gtr twin setup, I have upgraded to single setup. I also have alot of standard parts if anyone is interested, manifolds, dumps etc.
post-21954-1136610353.jpgpost-21954-1136610568.jpgpost-21954-1136610775.jpgpost-21954-1136610935.jpgpost-21954-1136611102.jpg
https://www.sau.com.au/forums/topic/100084-fs-gtr-turbos-dumps-etc/
OK I have updated with pics, HKS Dumps and Nismo pipe SOLD,
Turbos gotta go so open to other offers.
Im in Sydney if anyone else wants standard parts also.
Hey mate i want those turbos
PM Sent
