  • Replies 285
Posted Images
clothes line spec wings are so 2004... fulsick drifters these days have 3D carbon wings. P1's look insane. Our Sky80 has them as well on its rears (must be something with drift cars not being able to afford a full set) and they look horn.
BTW, make sure you take down the figures on the wheel before you return em (offset n all that).
nah nah
wait til u see em man, i just fitted em to the car and they look so phat :(
Clutch is in today, works a treat, turns out i had a nismo full face clutch in the car that was looking a bit worn, the flywheel was riddled with cracks so i ditched that. New clutch is a 6 puck Extreme unit specilly made to suit my car, peddle is lighter then before but there is heaps of bite, gave it a quick drive round ther block and it feels AWESOME to use.
then, after 3 hours (yes huddy 3 hours... record time haha) of changing clutches, and the drive round the block, i let it cool down abit (after consuming a few bourbons) then ripped the stock turbo off to fit my new KKR 430 turbo, and i have to say the KKR looks to be fairly impressive in size... i tried to fit it to the stock manifold only to find the compressor housing fouls this protrusion from the stock manifold that had a thread in it fopr the heat sheld.
gave up on that today, but tomorrow the Angle grinder comes out to play and i'll grind off that mount on the stock manifold for the sheild (there are plentyt other bolts still there anyway to bolt it on) then try to fit it.
After spending the better half of the day under my car i have found out the following.
- i have a full trust exhaust all stainless, with a hollowed out cat
-few dents in the rails... bit of work needed if im going to comply and register so i'll put it off for a while
-i have alloy stuff everywhere
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
