Located Brisbane
Price: $1,400.00 o.n.o
5 x 114.5, offset - 34mm
I have for sale my 17x8 Koya Drift Tek rims...these were on my car for only a month until it was written off. The wheels however are still in perfect condition. The tread on the tyres is probably 90% 235 rubber and they come with matching nuts and 4 security nuts.
These rims will fit straight onto an R33 GTS-T, R32 GTR and if im not mistaken S14's.
If you are interested send me a PM, email to [email protected] or contact me on 0417 624 234
https://www.sau.com.au/forums/topic/100566-17x8-koya-drift-teks-gold/
any pics of the wheels on ur car before the misshap??
i've got one of my skyline at the scene of the wreck, however you can't really see the rims.
http://image-cache.skylinesaustralia.com/f...-1131630720.jpg
I do however have a pic of them on a 32gtr if you like.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
