Hi Guys,
Yes I made it onto TV, and no it is not some porn show.
Me and my car will be on DriveTimeTV on this coming Tueday night, it's on Channel 10, late after Sports Tonight.
Luckily this time I didn't have to say anything, in fact they actually gaffa taped my mouth so I couldn't speak, it's true.
Tollie the host, takes my car and gives it a damn good thrashing, hand-brake turns and 360's, my brakes were smoking after he had finished, plus he managed to collect a few witches-hats while drifting it.
This was supposedly a drive comparison between my car and a 4-door Skyline they did a while back. They also had a Stegea wagon and a JZX90(chaser) which they will be roadtesting soon.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10061-pwptf-is-on-tv/
  • Replies 49
Geez your generous!! I have the look but dont touch policy on my car. Used to really annoy my ex after being together for 2yrs he wasnt allowed to drive my car and all his mates used to give him crap about it - then again would you let someone that has lost their license 9 times drive your car?
Will have to take a look!!!
https://www.sau.com.au/forums/topic/10061-pwptf-is-on-tv/#findComment-157490
too right!! I'd never let some other guy take my car out and give it a working! The only person who touches my car are my bro and parents (bro coz I trust he won't, and parents coz they drive as slow as a wet week anyway)
anyone else don't have a chance (annoying when your mates KEEP asking for a drive!!
But anyway, it wasn't my car, so will tune in and check it out
did they give you anything for the privelage of thrashing your car Paul? :P
https://www.sau.com.au/forums/topic/10061-pwptf-is-on-tv/#findComment-157615
The filming was done at the end of the drag strip at the Motorplex.
Tollie has been a rally driver for years, and knows how to drive a car better than most, including myself, so I wasn't too worried. My car is built to withstand a fair bit of punishmnet, so if something breaks I just fix it with something stronger.
See'ya:burnout:
https://www.sau.com.au/forums/topic/10061-pwptf-is-on-tv/#findComment-157724
so were you on ages ago? I seem to remember a gun metal line with silver and red rims ages ago, but at that stage only had a POD and exhaust or something? And that was a show saying they were gonna road test a few imports and apart from a 4 door skyline, they didnt do any.
Oh, and if you count the NA soarer they riced up, that makes 2.
https://www.sau.com.au/forums/topic/10061-pwptf-is-on-tv/#findComment-157890
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
