Sound deaden your boot panels / number plates to stop vibrations and panel flex. Also should do your doors too.
Look up products like Dynamat, G-Spot Serenity, etc.
//Edit: Read this link from FHRXStudios about deadening.
https://www.sau.com.au/forums/topic/100722-boot-rattles/#findComment-1837759
Its a bit messy, well a lot messy, but I like to use underbody tar, costs less than $20 for a litre tin and you can just smear it on all over the inside of your doors, works a treat. Grab some rubber gloves and tape some plastic bags up the length of your arms, if it gets on your skin its a bastard getting it off. I would still grab some matting for the boot tho just for asthetics sake...
https://www.sau.com.au/forums/topic/100722-boot-rattles/#findComment-1840958
Dynamat Extreme is awsome stuff. i really recommend it, although it isnt cheap. i put almost a total boot kit on the VS (it is a commodore, theyre designed to vibrate to bits :() and a wedge back on the boot. it sounds a million times better and hardly any rattles except for the outside door handle :)
https://www.sau.com.au/forums/topic/100722-boot-rattles/#findComment-1843407
Turn the music down... no just kidding...
Yeah sound deadening works a little bit, but its normally connections that will cause the problems...
the number plate, sections where a body kit touches other pannels... all those sorts of this... You can get a foam which is kinda like shaving cream with a nozzle like on WD40 and other degreasers to get into sections like that, and it goes stiff and can reduce some rattles... But I would only do this if you dont ever plan on removing any of those sections later...
- Crimpage
https://www.sau.com.au/forums/topic/100722-boot-rattles/#findComment-1851488
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
