i was wondering if anyone else has this problem... when ever im on boost and i go over a bump in the road my rear wheels will bounce but un evenly and it cuases alot of shakes noise and discumfort not to mention the car doesnt like it much either
i was thinking it might have something to do with my LSD or rear suspention not sticking the wheels to the floor hard enough ..
please help
https://www.sau.com.au/forums/topic/100744-rear-wheels-tramping/
Shock absorbers control the vertical movement of the wheels after the spring has been compressed (by a bump). What condition are the shocks in? You could try the old bounce test, push down on one side of the rear 4 or 5 times rapidly, and then release. It should retun to normal height without bouncing again. If it bounces its new shock absorber time. I would check the front as well, if the rear is stuffed, chances are the front is too.
If the bounce test looks OK, then my next guess would be rear subframe bushes. Have a quick look around the 4 bushes, marked in the following picture with the green dots;
What you are looking for is signs of leaking silicone, sticky goo and split or torn rubber.
Hope that was of some help
:D cheers :D
Edited by Sydneykid
Yeh ive done the bounce test b4 and that is fine .... im at work at the moment so i cant go n look at the bushes. my cars gett8ng close to 100kms im thinking that you may be right .. i just changed the front control arms ball joins were gone maybe its time to change all thebushes aswell
Also another thing .. this only happend if im excellerating over the bumps if i roll over then no matter the speed its fine
The tyres are transmitting the acceleration and twisting torque, shocks and bushes are both relied on to hold the torque.
:D cheers :D
i took my car out for a hard thrash last night and doticed that my car is tramping a lot more now. But ive noticed a little clicking noise now, when i ease off the clutch i can hear a clicking noise coming from the rear, its like with each revolution the wheels do it clicks. (the sound is kinda like if you have a rock stuck in you treds... but there is no rock in my treads) would this be related to anything i have been worrying about.
please if someone could help me ... if i were to take my car to a suspention specialist like Heasman at Tempe would i get charged an arm n leg for them to change my bushes or should i figure out how to do it myself
Get a quote
:rofl: cheers :rofl:
Do the pineapples provide enough reinforcement to hold the subframe if the origional bushes are or even worse WERE leaking.
Mine tramps like nothing on earth, on the dyno standing next to the car I could see the left rear wheel and subframe attached pull forward.
I'm about to throw a set of bushes through the front and sort out the subframe bushes, Sk you will receive a PM shortly. :P
Noltec do subframe bushes for the R32's, they can be had from UAS for ~$190, but as mentioned are a pain in the arse to get out for the usual home mechanic.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
