yeah you can get them repaired, but the repair will cost more than a $89 sub.. or at least veryt close too it if your lucky... i owuldnt bother personally.. and some of those pioneer subs go quite hard... depends what your expecting really... have a listen to them beofre you buy and see if they meet your requirements... but one thing to keep in mind... if your burning out voice coils you may want to look at why before you sink any big money into another sub (i.e not enough power from amp or running excessive power etc etc..)...
cheers,
damo
You can never have too much power :lol: just turn it down before it distorts, as an aside, if you have a dual coil sub, run them at 4 ohm - running at 2 & 1 ohm is for competitions, it heats up your amp and cabling and effectivly gives you the same sort of power with reduced lifespan from your equipment :huh:
  • 3 weeks later...
unless your emotionally attached to that sub for some reason, just go get a new one, ne that can handle the power of your amp... you will thank yourself for it... (buy in RMS, and buy a little under what the amp is rated at, but no more then say 50 watts...)
ive rooted voice coils before, i think ive rooted subs in every way. I once ran a sub so hard that the wires that took the power to the coil actually snapped! due to excessive movement. i thought it was pretty impressive, and a bloody easy fix too...
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
