Here's my situation:
1. My car heats up, by driving
2. I turn off the car
3. I try to start it
4. Starter motor doesn't work (sounds like battery is dead)
Complicating factors:
1. If I jump start it when this happens, it starts perfectly
2. Starter motor works perfectly when cold
3. My battery is otherwise very healthy - can run everything else fine when engine not running.
So, anyone else experienced this? Or have any solutions?
My current theory is that a hot starter motor is harder to turn over than a cold one, and my current battery doesn't have enough oomph left in it to do this.
Thanks
Greg
https://www.sau.com.au/forums/topic/100838-starter-motor-troubles/
More than likely it will be the battery. If it's old and on its way out, as it gets hotter while the car is running, bubbles will form on the inside of the battery electrodes and this will cause it to not have enough power to turn it over when it is hot. Also check the wiring is connected correctly to the starter, more importantly the ground wire
if your car doesnt start when its hot but all your car accesories function ie windows wind up and down, cd player works, then get a new starter motor cause its on its way out. i had these symptons, replaced mine and now it starts whether the weather is hot or cold.
Yeah this happened to me a few times, the last time it happened i was filling up at a servo and when i tried to take off the car wouldnt start!
To make matters worse no one was willing to jump start the car for me :rolleyes: I asked about 5 people, until finally guy in a V8 turned up and helped me out.
Well anyway the next day i got the battery replaced and its been fine ever since.
To make matters worse no one was willing to jump start the car for me :blink: I asked about 5 people, until finally guy in a V8 turned up and helped me out.
just clutch start it. jump start take too long and is too much hassle.
To make matters worse no one was willing to jump start the car for me :( I asked about 5 people, until finally guy in a V8 turned up and helped me out.
lol on saturday the exact same thing happened to me at a servo. ended up roll starting, although there was only just enough room. i've ordered a new battery through wrxhoon's group buy so hopefully that will solve it. if not, i'll get a new starter motor.
Thanks for all the suggestions guys. I put in the battery I got through wrxhoon for $140 (equivalent to an Odyssey 1200). The engine cranks over much more quickky and I had no troubles starting the engine all weekend on a trip to phillip island, where the engine was probably the hottest it has ever been thanks to the 40+ degree temperatures.
Problem solved!
Edited by Greg
I've also just started having starter problems... R32 GTS4.
Battery is reasonably new ~ 6 months, and appears fully charged on the battery charger. But wont turn over at all. Roll starts and drives fine, but won't turn over.
Going to investigate the battery more tonight, otherwise the mechanic'll look at it tomorrow.
I'm hoping its a new battery : )
thats your starter motor. if you can roll start it but not able to start it standing still thats your problem.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
