I want to put a turbo kit on my R32 GTR and i want a response car. so if any one can steer me in the right direction that would be great. my r32 is basicly stock has a exhaust. so any other parts that might help me with making a response car please tell
https://www.sau.com.au/forums/topic/100875-gtr-turbo-kit-help/
how responsive are they. what is the rpms a soon as full boost comes on?
http://www.skylinesaustralia.com/forums/in...p?act=Search&f=
cheers.
Its all covered, depends on your engine spec.
Have a read of the threads.
Same thing for 2530's
GTR Garrett 350HP Upgrades
707160-5
pnblight uses them in WA and makes 500+rwhp with supporting mods
They bolt up to all the standard oil and water lines as well as dump pipes
several customers have pointed out, that they see a difference of 3-500rpm
Thanks
Tarek
RACESPEC
this is not the for sale section, traders can use thier own sections freely, not FI
cheers - R31Nismoid
the best two units are
Garret gt2560r 707160-5
Hks 2530
I personally not very interested in the gt-ss as you loss top end with no real gains in the bottom end over the 2530 or gt2560r (personal opinion )
both direct bolt on and both very similar, if i had to pick the differences the garret will spool a little earlier and make a little more hp at lower boost BUT the HKS is capable of high boost and comes in to it own in this area but these not a lot of motors that will run 1.5 bar plus which is where i believe the HKS start to over come the garrets
Racespec can supply the garret at a very good $$ much cheaper thean the hks unit new out of japan (comparing new with new)
I have run the garret turbos through all the stages of my build up from std with exhaust 12.08 1/4 miles (std air box ,injectors,afms, ecu ) to 529.4rwhp at 20 psi
pete
2530's mate...i made over 440AWKW on race fuel and over 400AWKW on pump gas also made 467RWKW on 103unleaded....runs 10.3's and goes like a rocket off the mark..1.4-1.5 60' times...i might have a set for sale if you are interested...pm me
Edited by DiRTgarage
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
