  • Replies 73
actually my 3" pipe is silent... i reckon it would scrape under the 90db mark it honestly isnt that lud at all.
as for stickers... the only stickers going on my car will be the SAU VIC stickers we end up making.
https://www.sau.com.au/forums/topic/10100-coppas-everywhere/#findComment-158057
Hey Inark,
What 3" exhaust u got? I got Trust MX... I read the spec that the tip diameter is the same with Apexi N1, so was wondering if the N1 optional silencer will fit in nicely in the Trust MX? (Just need to drill a hole in the tip to hook up the silencer)
I actually don't think my exhaust too loud, but it should be able to make it quieter whenever you don't wanna attract too much attention.
https://www.sau.com.au/forums/topic/10100-coppas-everywhere/#findComment-160285
Originally posted by pushead
i heard they superglue it onto the glass and you need some 'special chemicals' to get it off....
trust me i have done this before!
u just scrape it off then use sum bug and tar remover to clean the glue off! It can be taken off quite easily!
https://www.sau.com.au/forums/topic/10100-coppas-everywhere/#findComment-160372
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
