  • Replies 101
Originally posted by inark
no way! GTT pretty much stock... around 27k landed not inc rego
You are dreaming if you think you can get any sort of 34 with a turbo for that price! unldess of course it has like 150,000 kms on the clock or it has been welded back together or lastly it was stolen in Japan.
BEWARE *anyone trying to buy a 34-turbo this cheap* - there has to be something wrong. I should know, I do months [if not years] of research when buying a car including my latest purchase; a 34 gtt that i just bought in november last year.
I do know of a few dodgy operators out ballarat way too! I won't name names for obvious reasons but if anyone is serious about a purchase I may be able to help you steer clear of certain trouble...
The problem with chat-forums is that *there is a lot of fiction-based info spread around that has no supporting evidence* dont say you werent warned!
well actually seeing as i browse around all the auctions i dont base my findings on fiction... ur not the only one that has been researching imports for a couple of years.
there was also another one that went thru about 3 weeks ago... black... no wing... TURBO... was a 99 model... nice rims and a POD filter and aftermarket front bar and that went for 31k.
there was a top secret GTT that went thru the auctions not that long ago that went for 38k landed and complied ie. everything but rego
was sex.
That sounds like the white one, with aftermarket bonnet inc vents, wheels etc...I know who is selling this one too! A nice looking car in the flesh also :(
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
