Hey what's up.
I was just wondering if you guys could maybe post what you've done with your aftermarket gauges? There's always the A pilar pod's and center console area (which I'm using in my 240) and I'd like some ideas for my Skyline.
So if possible let me know and post up pic's too.
Thanks fella's.
Cheers B)
https://www.sau.com.au/forums/topic/101029-some-gauge-placement-ideas/
Hey what's up.
Thanks fella's.
Cheers  B)
Personally i'm a big fan of those three gauge modules that sit center dash that you always see in dvds of cars in japan but i'm still to locate any here.
With the admission that I haven't even tried yet so if any one has some insight, it would be most appreciated!
Yeah that pic you posted is well.....a little to busy for my liking.
With those side pods on the dash, they raise them up and it's to bulky looking. I want to go with something cleaner.
I'm thinking of just using a couple on the dash in seperate pods, group the wires together and cover them with a plastic wire cover so everything is hidden. Simple I know but functional and estetically pleasing to the eye.
Hey nathn_r33 I just wondered, in your pick there's an oil pressure guage. Was it hard to hook up as in, did you replace the stock sending unit with the one that came with your gauge?
Keep the pic's coming guys if you can. I am still waiting for something to jump out at me that I may steal the idea. :P
if memory serves me correctly, we imported a pod with the 3 gauges to the left of the cluster from japan for a fibreglasser in melbourne. They did do some copies, but for the life of me I can't remember their name... I'll see if I can dig it up.
They look horn though, one of my mates has an original triple cluster pod in his R32 GTSt. They'd look so bling with a set of Defi's in em.
Keep the pic's coming guys if you can. I am still waiting for something to jump out at me that I may steal the idea. :wub:
Yeah I did replace the sender. The only hard part was that some tool that had the car before me had bent the original sender so when I got it out it cross threaded the thread in the engine. I just replaced the original one drove to the closest work shop and got them to re tap the thread. Put the new one in and haven’t had any trouble since Other than that it couldn’t have been easier. Nathan
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
