  • Replies 188
Posted Images
  • 1 month later...
nar, i am just starting the build... it is still practically stock atm... getting a 6 point cage soon and a proper race seat and harness set-up(6point)..
i did FOSC Bathurst last month (BEST TRACK EVER! 231km/h in a basicly stock motor 1.8L N/A is awesome down conrod :D) and have been competing in NSW CAMS Super Sprint topping my class (2b and faster then 3B) now i am more hooked then ever and want to get in to proper racing :D being just 19 yrs of age is the perfect age... got in to it through my old man as he is very much in to the track scene with his modified 90' MX-5 Turbo..
Joined up as a mate (MattD) told me 2 join up and 2 see if i could make it to some Canberra event you guys are holding.. but cant make it this yr maybe next yr when they car is closer 2 completion ;)
Edited by Dave R
Have you thought about production cars not improved production? We have a class for fwd and there is already another integra in it. Cheaper than IP because less mods are allowed. Should be great fun either way
  • 3 months later...
I plan on getting my cams license soon (L2 speed) and starting out in some club sprints/trackdays etc.
I also have a question regarding insurance. I am currently on my p's and i'm looking to get some insurance for my car (S13 Onevia).
Are shannons more likely to give me insurance because I have a cams license/compete in club/track events even though I'm on my P's and under the age of 25?
I had Just Car insurance on my previous car, and I was very unimpressed with their customer service/cover etc..
its cheaper if you are a member of a car club
  • 2 months later...
Just renewed my National Rally Nav Licence.
Paid extra for their super quick processing and it still took over 3 weeks for it to arrive in the letterbox grrrrrrrrr
CAMs could learn a thing or two from AASA when it comes to licencing.
hmm and as usual for cams "rush" license it literally turned up the day after you left for the event. glad we paid extra for that "service"
the dickheads can't even send out licenses on time, its no wonder people would rather deal with aasa.
  • 1 month later...
  • 1 month later...
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
