Hey guys.. Just got my skyline 2 weeks ago and yeah my electrics is playing up. When i turn the car on all the power doesnt work. Like the dials dont work, the aircon, blinkers and the power steering. The headlights work still tho. Im not sure whats going on. About a week it was working after 5mins of running the car and now it just stopped working. Has anyone had this problem or would know how to fix it??
https://www.sau.com.au/forums/topic/101223-electrics-is-playing-up/
Straight to an auto elec... could be a million things... Could be an earth, could be a multitude of fuses... Sorry I can't give you any specific help.
Edited by Crimpage
I had a similar problem and it ended up being the reverese switch on the gearbox was damaged. It caused all types of weird problems some of which yo are having. Id suggest getting to to an auto elec ASAP. Lucky for me I replaced the switch and the battery cause it drained it beyond charging.
Also my alternator was a 50/50 chance of working again too luckly it wasnt stuffed though.
Edited by alphanumeric
yeah maybe my reverese switch on the gearbox might be damaged. The other day i put it in reverese and it worked and then stopped working agains.. by the time my windoes were down and now i cant get them up. how much did it cost u too fix???
Get someone to check if your reverse lights come on when you pop it into reverese thats the easiest way too tell if its the switch or not.
Also you probably cant get your windows up because you have blown a fuse. Do your instruments on the dash work?
hey i checked the reverse light and yeah its not working either. i checked all fuses and yeah its all fine. The fuses were abit greesy tho?? is that suppose to be like that???
Its either not getting power to the switch or its damaged like mine was. Bets thing to do is take it to an auto elec tell him all the problems and he should be able to locate it pretty quickly. If you have a mate that has a hoist get him to put it up on one and check the switch yourself. It might be the the problem or it might be something else its hard to tell with electrics.
Good luck!
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
