Got my car back this afternoon from the mechanic. He didnt change the afm, basically gave it a check over, put it on the dyno, drove it round on the road a bit and said he couldnt fault it. Got it back on the highway and within 5 mins i had created a traffic jam! The problem is very easy to instigate, if i drive it gently and not on boost, all seems ok, if i give it some, say 1/2 bar or more, after i stop accelerating it basically looses all power, splutters, shudders i get very little response form the accelerator (if any) and if i fully remove my foot from the gas it will stall but i can keep it alive by pumping the accelerator, eventally it springs back into life as if nothing happeded. If i accelerate hard again same thing happens. Any ideas??
Cheers
Twitchy,
Sounds similar to a problem I had (and which we eventually fixed). Car would run like a dream and then, for no apparent reason, loose all power, survive a complete stall by pumping the accelerator, then after about 15-20 seconds, it would come good again and off we go. Kept happening at the most inappropriate times.
Same deal, we thought AFM, replace both (paid about $150 each second hand). No good. Changed fuel pump, checked wiring, relays, computer, CAS, spark advancer - basically everything you could think of. Mechanic would say - "I think we've got it now" after they road and dyno test - only to do it again on the way back to work.
ANYWAY... turned out to be the plug to the computer. It has a single bolt on the centre of the plug. As the car accelerates or brakes, the plug would rock - ever so slightly - and lose connection with the fuel pump pins. Used a bunch of zip ties to hold the plug firm on the edges - never had a problem since.
It's a long shot - but if it is the cause - you may not have thought to look at it.
Hope you get it fixed soon.
Cheers
Peter
Hi Peter;
that's a beauty, how did you manage to find it?
GTR 32,
I think it was when they were changing over the ECU (from Apexi back to stock back to Apexi) when they noticed the plug - which is actually more like a bar had a slight bow in it. I would have been stuffed otherwise - it had taken 3 weeks of trial and error, calling in auto electricians, 2 fuel pumps, etc, etc, etc when someone came across this.
At one stage, whilst at the mechanics, we couldn't start the car. Put a pressure gauge onto the fuel line and had zero pressure. Everyone stuffed around trying to work out why - no go. One of the guys leant up against the car - hey presto, full pressure.
Was driving us nuts.
Definitly worth a check if you experience any wierd stalling as described.
G'day Peter, very interesting reading your reply, sounds almost identical to my problem. I havnt heard back from the mechanic since i gave the car back to him last week (wednesday) so i gather he hasnt fixed it. First thing tomorrow i will ring him and let him know about your problem and solution. I have a feeling that it is an electrics problem due to some other strange things (electrical) that have happened in the past...he's not so sure though. I really appreciate your advice and will be sure to let you know the out come.
Cheers
Andrew
I didnt realise how lost i would feel without my car :rofl: i usually walk around with a big grin on my face, however since that fateful day last week i seemed to have lost such an expression :) (never thought i would feel like this about a car).
Edited by Twitchy
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
