***ENGINE NOW SOLD, PLEASE SEE LAST POST RE: WHATS LEFT***
I've got all the bits from an RB25 DE front cut (plus some other bits).
I was going to build a RB30det, but my new project says no :O
Its pretty much all the bits you need, bar a turbo, some machine work and assembly is required of course. Cubes wrote a great how to on this motor :)
I'm chasing around $1300 for all the below parts, if you'd like to make an offer, PM me and we will see how it goes. This includes delivery to Melbourne, Sydney or Canberra via a trailer to your door.
The front cut was worth around $2000, plus there is 3 years worth of R32 modification leftovers.
The obvious RB25 DE head (still attached to the rest of the motor). In good condition, and from a healthy motor that still would run (if it was in a car).
Oh, and for the record the obvious RB30 block IS included. I've got two if you'd like them both. You could build a V12 by strapping them together! awesome.
I'd really rather sell the whole lot - I have run out of room in my garage, and I don't need any of this stuff :) I imagine you don't need it all either, but it could be sold for profit. .
If you really just want the head or bottom end, or both pm me and we will talk.
Below is a list of all the other parts you'll get.
Car showed 88XXX kms, which was about right I'd say.
Auto GTS Dash in great condition
A/C "radiator" (I think its called a condensor - the thing that sits at the front)
A/C compressor, lines and all that stuff (no gas of course)
Heater box from behind the dash
Ashtry (with woodgrain for some reason)
RB 25DE bottom end, in great conditon
RB25DE Computer .
Auto gearbox computer -
Coil packs x 6. Checked them over and they look ok, no cracks or anything..
Suits RB20DE, RB20DET, RB26DETT and S1 R33 GTS-T and RB25de of course (also your new RB30)
Full R33 2 door dash with vents (no cracks, looks fine)
Glovebox
Surround for cluster
Kick panels (both sides)
Steering arms from both sides (with stock suspension in good nik - no leaks) they are 4 stud though)
Steering Rack
ABS module
Induction pipes/air box (whole thing) (suits turbo car or NA) WITH AFM
Radiator in A1 condition (no bent fins - same as a turbo one)
All plastics from around the front of a 33 (wheel arches and splash gaurds and stuff)
Brake lines (all of the metal ones)
Auto gearbox fom the above car, Gearbox is in good condition with around 88000 kms on it. Its the same model as a turbo one, so if you struggle with your left foot, it'll be right up your alley.
Apparently its a 5 speed too, I'm not sure but thats what I was told when I bought it. Either way it appears in good nik.
Also have a VL N/A head, enjoy that as your new boat anchor!!!
Any questions you can PM or mail me.
Cheers!!!
you may just want to include wether this is an RB25de from an R32 or R33.
r33 ones have VVT and ot suitable for R32 owners...
good luck
Thanks for that - I didn't know.
The car was a S2 R32 GTS with the 2.5 DE motor. (1992 model).
sorry for the double reply.
but this line from your add.
is that a typo?
is it meant to be R32?
if it is supposed to be an R32 (since all the other parts seem to be), then I will buy the 3 air con vents from you..
let me know please.
Na, thats an oddball bit that popped up in amongst everything.
Anyhow, it appears the two engines are gone, so I'll separte all the rest of the parts next week in a new ad with some piccies.
P.S. Nice sig!! LMAO
ENGINE IS NOW SOLD!!!!
These are all R33 bits from another auto car that was here for a while :)
Speedo, Tacho and all that jazz (showing very low kays) - $50.00
A/C "radiator" (I think its called a condensor - the thing that sits at the front) $40
A/C compressor, lines and all that stuff (no gas of course) $20
Heater box from behind the dash $20
Ashtry (with woodgrain for some reason) $whatever you like
RB25DE Computer . $40
Full R33 2 door dash with vents (no cracks, looks fine) $50
Glovebox $20
Surround for cluster $20
Kick panels (both sides) $20
Steering arms from both sides (with stock suspension in good nik - no leaks) they are 4 stud though) $100
Induction pipes/air box (whole thing) (suits turbo car or NA) $100
RB20 AFM $80
Radiator in A1 condition (no bent fins - same as a turbo one) $50
All plastics from around the front of a 33 (wheel arches and splash gaurds and stuff) $20
Brake lines (all of the metal ones) $20
Also have a VL N/A head, enjoy that as your new boat anchor!!! This is free to a good home :D
Offers accepted :) This stuff just needs to go :)
Cheers!!!
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
