Hi Guys,
I am building up a Series 1 RB25DET that i bought to put into my Datsun 240k. I am looking to buy the Nissan VRS kit or the full nissan kit (as i will eventually do an RB30DET conversion).
I want to ring up nissan tomorrow to order a kit, but this is going to be difficult because i don't have a corresponding VIN number i can give them.
does anybody know for sure what the nissan part numbers for both the VRS kit is and also the full kit for the Series 1 RB25DET (Manual)
and if failing that, would anybody with a Series 1 GTST mind PM'ing me their VIN number so i can order the correct parts from nissan tommorrow?
is there a difference between S1 and S2 kits?
thanks
Kent
and the full kit part number is 10101-17U26 RB25DET Gasket Kit - Engine Repair
it contains:
1x Gasket goo (150g)
1x drain plug washer
1x cylinder head gasket
1x crankshaft rear oil seal
24x valve stem oil seal
1x rocker cover exhaust gasket
1x rocker cover intake gasket
2x camshaft oil seal
1x crankshaft oil seal
1x intake manifold collector gasket
1x manifold gasket
1x exhaust manifold gasket
1x oil strainer gasket
1x oil pump gasket
1x throttle chamber gasket
1x soeal o ring
1x AAC valve gasket
it contains:
1x manifold gasket
1x oil pump gasket
1x soeal o ring
1x AAC valve gasket
What did that end up costing?
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
