hey guys,
i have a R33 GTS-T and i want to do it up. i have 17" rims and a 3.5 inch exhaust all the way through with a 4"inch tip and sports suspention and everything. WHat is the next thing i should do? SHould i put a frount mount in? Boost control? Can anone give me some ideas?
Thanks guys
https://www.sau.com.au/forums/topic/101463-what-should-i-do/
1. fmic get a kit trust one is good I hear. $450 - $2000
2. dump pipe from turbo to cat
3. high flow cat $3?? supplyed and fitted
4. safc2 / or remapped ecu anything from $200 to $600
5. boost control $22 to $600
try and find good second hand stuff, but get a new highflow cat (i have a magic 4")
Then after all that you can go onto things like
1. turbo $400 - $3000
2. injectors $400 - $1000
3. forgies and rebuild dont ask the price.
4. powerfc. $950 of here
Most stuff you can find on here for next to nothing or become friends with your local performace shop. Have fun.
Upgraded brakes and discs might be a good investment to keep this power under control. I know that would be something id be looking at. either GTR brakes or even 300zx brakes i hear work nicely. this could make it that little bit cheaper aswell
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
