Basically chasing up a set of tyres - 245/255/265 (9 inch rims) x 17inch x 4 for a R33 GTR. At the moment I need four tyres. I purchased some Falked Azensis ST115 245/17s for the rear about 12 months ago and I'd be lucky to have got 10,000 km out of em (and thats with very moderate driving) for $320 each from Quickfit. So I guess they were a bit soft but I don't really wanna spend $1200+ for tyres lasting less than a year. So I'm in the market for some decent tyres- new or used at a reasonable price.
Anothther option I had was tempE tyres in Sydney. They had:
some Dunlops in 255 40 17 ($250ea inc freight).
some falken zeix 512 ($230ea inc freight).
Of course, then you would have to pay for fitting, balancing and alignment. Which begs the next question - who would be good to fit/balance/alighn tyres for a decent price. I could fit them myself but they wouldn't be balanced and would need an alignment. Just wondering if places would it do and how much, bearing in mine you bought the tyres from somewhere else (+some places have the fitting machine so it probably wouldn't be worth my time to put em on anyway). So any recommendations??
Cheers,
Pefnold
https://www.sau.com.au/forums/topic/101647-tyre-dilemmas/
Firstly, have a look at the sticky thread at the top of this section on tyres and how you rate them. By the sound of things you want a reasonable tyre which will last. Unfortunately, you get what you pay for in most instances. High performance generally comes with high wear. Anything that does both comes with high cost. My suggestion would be to have a look at the Hankook Ventus Sport K104. These appear to be a well priced, long lasting, reasonable performing tyre.
https://www.sau.com.au/forums/topic/101647-tyre-dilemmas/#findComment-1862589
I'll give you my 200 cents. I wouldn't touch falken ziex or any other crap tyre with a 20ft pole.
You get what you pay for. I was once young and stupid and did just that. I looked at the pattern of the ziex 526 I beleive it was, and thought it looked pretty 'race spec' (reads - gives good traction). In the rain, on a rwd car, it was like driving around on ice.
You should be targetting the source of the problem, not a cheap fix. Obviously your wheels are out of alignment for the tyres to be dead after 10000ks. The St115 are good tyres. Another alternative is the falken fk451. They're both very good.
The tyres themselves are not that soft. With good alignment and 'moderate driving' as you said you did, I don't see why they won't last 20000-30000ks.
I've got a set that has done 15000ks and it's still got quite a bit of tread left, I dare say more than 5000ks (A friend of mine used these for a bit then gave them to me. His job involves a lot of driving. The car is a 32).
https://www.sau.com.au/forums/topic/101647-tyre-dilemmas/#findComment-1862975
Well ran round & got some quotes (fitted):
Hankook K104 - 255/40R17 - $260
Falken 326&512 255/40R17 - $320 (wont touch)
BFGoodrich Profiler G 255/40R17 - $315
Kumho KU21 255/40r17 - $260
Rest of places laughed & quoted like >$500 for Bridgestones, etc. One guy told me to get 235/45R17 Bridgestone TZ100's for $185.
Feedback? Saw someone got the Hankooks for $200 somewhere????
Cheers,
Penfold
https://www.sau.com.au/forums/topic/101647-tyre-dilemmas/#findComment-1865440
About 500 a corner is right for the sort of tyres a GTR deserves :P
Depends where you buy them , i got T1R'S for $340per corner for 275x35x18 .
You are correct though the normal retail is close to $600 .
https://www.sau.com.au/forums/topic/101647-tyre-dilemmas/#findComment-1867446
bloody good price!  is that deal available for anyone else? they are good tyres too
Not now Duncan , that was about 6-9 months ago , i got several sets ( 20 tyres all up) for some forum members that took advantage of this when i put it on the forum at the time .
I know a couple of wholesalers and i can get good deals from time to time , by the way that was for tyres only ( no fitting ) but still a very good deal .
https://www.sau.com.au/forums/topic/101647-tyre-dilemmas/#findComment-1870975
i agree with the falken ziex being one of the worst tyres around,lost it a few times under no throtle in the xr when it would ran, not much better in the dry. i run goodyear eagle f1's now best tyres i have used also have used goodyear revspecs also very good and well priced. for the gtr next time i will get f1's.
ring goodyear in bankstown 9790 3919 and ask for david tell him norm sent you will look after you.
mr 32
https://www.sau.com.au/forums/topic/101647-tyre-dilemmas/#findComment-1871056
federal ss595. dont knock them till youve tried them. the best old road tyre ive used.
abit doghy till there warm. then they come into there own. very predictable and they give good feedback.
they suite the gtr very well. they need to be treated agressivly to get the most out of them. when they feel like they are loosing grip they keep on gripping harder. quite a wierd sensation.
-2.5deg camber front/-1 deg rear camber/9deg caster/2mm toe out on front/5mm toe in on rear/ slightly lower at the front ,whiteline swaybars. rear hard front soft.
500lb front springs, 400lb rear springs :(
6 months worth of trial an error getting this set up that works and doesnt understeer. for my 32gtr :lol:
they were better than s02,re01,fk451,gIII potenza, re03 potenza, sp sport9000
the main diferance was the leval of heat they could take. they did not get all "ski-jumped".
but they run best at 34-36psi hot
this is on a r32 gtr. 255-40-17. nismo lm-gt2 17by 9inch.
FOR $185 EACH NOTHING COMES CLOSE. to be quicker round corners than those crazy honda guys that hit the old pac everynight. federals are doing ok.
https://www.sau.com.au/forums/topic/101647-tyre-dilemmas/#findComment-1886007
I find its not just taking the heat, but taking the heat cycling. The constant heat up and cool down cycles of tyres make them go hard after a while. It happens to all tyres, but some tend to resist it better than others. Quite often this is where the expense comes from - using compounds that are resistive to this cycling yet providing grip, comfort and durability.
https://www.sau.com.au/forums/topic/101647-tyre-dilemmas/#findComment-1889275
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
