Do they come with wastegates Daniel?
cheers
Chris
Most of them do in the smaller ones Chris. by small I mean GT2860R or smaller. Some of the larger ones do but is rare. I can let you know if they do if you have one in mind.
Also you can use your standard actuator on a new turbo if you like....the actuator still does the same job.
https://www.sau.com.au/forums/topic/101678-turbos/#findComment-1864878
I got the price back to graft the RB turbine housing onto the GT30R and it is around $2150. You would need around another $150 to get the braided lines for water and oil done and to make up something for the 4 inch inlet. But still rated at 500hp with the RB rear on it and still bolts straight up to the stock manifold and dump pipe.
https://www.sau.com.au/forums/topic/101678-turbos/#findComment-1864885
yo dan mate
i notice no gt3240s etc?
those not available. (not intrested for me - just a general intrest)
thanks
mick
Yeah they should be mate. I just don't think they are called that anymore. Can you tell me what hp rating they were and possibly what exhaust a/r they came with. They will match up to something on the list somewhere.
Oh and BTW, I am sorry to say that due to the fact that the T04Z's sold out before they hit the shelf....Garrett in their infinite wisdom have decided to jack the living crap out of the price on them.
They are now $2165. Retail on them has jumped to $2750. Sorry mate. I hope you didn't end up wanting one.
I'll also send a message to my rep and find out what might match up to the old 3240 that you know.
https://www.sau.com.au/forums/topic/101678-turbos/#findComment-1871740
Dan might be an idea to have a matching list of specs (or add additional specs) to the price listing
I would also think that should you be able to get something that bolts onto the existing manifold and dump with minimal intake mods and new oil and water lines and you would make a KILLING
https://www.sau.com.au/forums/topic/101678-turbos/#findComment-1872173
I can get it done to the standard manifold...no probs at all. I am going to price up how much to make the adaptor plate and then how much to sprayweld it to the manifold....it's the only proper way to do it.
Shouldn't be anymore than say $150 but problem is the dump pipe still won't go up to the T2 style flange...that's where you have the problems.
I'll figure something out though.
https://www.sau.com.au/forums/topic/101678-turbos/#findComment-1878663
ripper yeh gt 3240 approx 600hp-700hp with a 0.82 exh
thanks dan
yeh dont worry about t04z :D
That was easy. The turbos in the list rated at that much horsepower and with the 0.82 are the 714568-2, the SB8006A (which is what was used to be called a GT30R), and the GT3582R-IW which is an internal wastegated version of the 714568-2. Price on those is $1850 and $1890...(don't forget my PM)
Cheers, Daniel.
https://www.sau.com.au/forums/topic/101678-turbos/#findComment-1878685
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
