  • Replies 46
Haha, I bought my car on september 2004 and did some extras around 5 grandish so I lost about 10+ :P
I'm losing as well :O What to do man hehe.
It's just , we are selling the car at the wrong time.
I hope you can sell it as soon as possible, price drops each week.
Drive a VII or a VIII before you say you don't like it :P Esp the jap spec, with same quarter mile time and same handling as a IX... same chassis / suspension setup, remember :)
Blinky,
If all else fails i guess you could just wind the kms back like most others do!!
Then sell it for thousands more than its worth. At least you have a honest car for sale!! Good luck with the sale mate.
I'm pretty sure I actually have the japanese export/shipping papers at home somewhere.
I had 80000kms on it when I bought it fresh from import. So I've only driven it 15000kms in the last year and a bit.
I know what you mean about low odometers, all the ones in the tradingpost and on carsales have half the amount of kms mine has. I wonder how many of those are genuine ?
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
