In about a week's time i will have a R34 RB25 turbo for sale... perfect for high-flowing as it's got a larger housing than the R33s.
If not high-flow, the turbo is still in perfect order and goes very hard :P PM me if you're interested!
https://www.sau.com.au/forums/topic/101782-200rwkw/page/2/#findComment-1913355
If not high-flow, the turbo is still in perfect order and goes very hard ;)  PM me if you're interested!
I've got one these turbos on my r32 and it goes hard! When the car hits boost it absolutely flies. Good for 190kwatw so I am getting there. Would have to say this is a great first upgrade if you want a bit more power and its reasonably inexpensive too :rofl:
Edited by patto1234
https://www.sau.com.au/forums/topic/101782-200rwkw/page/2/#findComment-1914267
on my r33 rb25det im curently running 11psi, apexi power intake pod.. but im guessing somthing else was done b4 i got the car that i cant notice (cam gears? hi flow? ecu remap?) but its curently at 195rwkw with the stock corner mount (yeh sux on hot days, have to take it easy).
https://www.sau.com.au/forums/topic/101782-200rwkw/page/2/#findComment-1937418
Just an update. I have installed an Apexi Power intake, made brakets for it and plumbed up a better CAI. I have purchased a justjap stage 2 FMIC and that will be going on this week. I got the car re-dyno'd and it came to 148rwkw. The dyno the previous owner used must have just been an optimistic one.
Once the new intercooler is on Ill be setting the boost to 14psi and start looking for a new turbo.
https://www.sau.com.au/forums/topic/101782-200rwkw/page/2/#findComment-1944304
oh really?
with stock turbo, GTR cooler, 3 inch Trust Exhaust, HKS filter, GTR fuel pump and Greddy Profec EBC i ran 1 bar boost, and made around 155 rwkw's, the thing had plenty power.
now fitted with KKR 430 turbo, and at the dyno as i type. it should be good for 200 rwkw, with stock AFM, ecu and injectors.
Turbo will support 250 rwkw's if i can get injectors and AFM changed with a retuned ecu.
Edited by simon-ae86
https://www.sau.com.au/forums/topic/101782-200rwkw/page/2/#findComment-1944371
I am curently making 165 rwkw (221rwhp) on stock turbo and stock boost in shootout mode.
All i have done is front mount, exhaust, fuel pump and ECU.
I have not touched the boost on the thing so it should be at the standard 10-11psi?? That is what the RB20s run isnt it?
Soon i will have a FMIC spray hooked up and will be winding the boost up a bit.
Edited by nissan_280zx
https://www.sau.com.au/forums/topic/101782-200rwkw/page/2/#findComment-1945006
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
