NEW Bosch/Nissan Z32 Airflow Meter.
$300
+ registered post. + $6.35
+ insurance if you wish. + $3.30
http://www.auspost.com.au/
I will only send via registered post as it provides proof. :(
If in SA pickup available
Direct Deposit only.
I can supply plugs OR you can zip down to your local wrecker and pick up a second hand item from a VL or R31 RB30E.
Providing we can get 15 plugs together they plugs can be done for an extra $10.70 each.
As the AFM is a new item from Bosch.
Bosch make the Airflow meters for Nissan.
Buy a Nissan afm and you will find Bosch/Jecs markings on it.
The Bosch Z32's RRP is $450, trade is ~$390.
From memory Nissan want ~$600 odd.
Interested Persons:
1. 4door_Sleeper - 1 AFM
2. mickr33 - 1 AFM
3. NARDI - 1 AFM
4. dangerman4 - 1 AFM
5. r32_rookier - 2 AFM's, 2 plugs
6. dacow - 1 AFM
7. Iceduck312 - 1 AFM
8. driftstick - 1 AFM, 1 plug
9. Fat32 - 1 AFM
10. Shaun - 1 AFM, 1 plug
11. Sky34 - 1 AFM, 1 plug
12. BOZ22N - 1 AFM
13. Pretender - 1 AFM, 1 plug
14. JL - 1 AFM, 1 plug
15. ausgtr - 2 AFM's, 2 plugs
16. ---- - 5 AFM's, 5 Plugs
17. YLD-CHLD - 2 AFM's, 2 plugs
18. B0oStEr - 0 AFM, 1 plug
19. Skylinecoupe - 1 AFM, 1 plug
20. clayoth - 2 AFM's, 2 plugs
21. Speed safe - 1 AFM, 1 plug
22. Predator
23. SKY34
24. Fangz
Total AFM's - 29
Total Plugs - 21
Due to a shortage of supply the group buy will not go ahead until....... Bosch are ready. :D
According to Bosch: At some stage there was a manufacturing problem that caused a lot of back orders.
They estimated they would be in surplus by the 1st of May.
Its now the 1st of May and they still have backorders.
Z32 Airflow meters are available in small numbers around various suppliers for the full price but as I said... In small numbers. The supply to these suppliers obviously takes priority over our group buy.
To my surprise, I received a call early this morning, Bosch have now pushed the date to the 1st of July.
Either way, 'eventually' our group buy will go ahead.
For a new afm that you don' t have to worry about for another 10years its an awesome price.
Edited by Cubes
https://www.sau.com.au/forums/topic/102021-eoi-new-z32-airflow-meters-300/
  • Replies 134
Posted Images
Possibly? I don't mean to sound harsh but I really don't want to be buggered around on this as I'm not making anything on it, in fact its costing me slightly.
For future ppls possibly interested, please be sure if you are interested or don't mention you may be. :P
Edited by Cubes
cubes, you said 'interest' i posted an interest but having re-read my post i think you misunderstood.
i need one for a current car and pending the arrival of a car from japan i might need a second....hence "possibly 2" not "possibly too".
If you have the part number you can buzz any auto parts store and they will give you a price on the Q45/VH41.
Retail for the Z32's are $450.
They can be found at trade for ~$390.
Edited by Cubes
No.. If you want the plug head down to the wrecker and grab one from a VL or R31.
I do have wiring diagrams for both the R32/R33 S1 and the R33 S2.
I don't have wiring diagrams for the GTR's. If some one does, please drop me a pm and I will grab them from you. :)
Its not rocket science though, easy to wire, you have a + feed, earth(s), signal.
Edited by Cubes
Bosch make the AFM for nissan, as NGK make the oxygen sensors for nissan.
So in short its a Bosch AFM, as is the afm you buy from nissan.
See initial thread start post for pics I've attached.
You can see to the left of the flow direction where nissan have their nissan emblem stamped.
Thats correct, you will need 2. Do you want 2?
2 RB20/25 afm would probably meet your requirements depending on power goals? 400rwkw+ will require Z32's.
Edited by Cubes
When will the deadline to pull out? I'll need to confirm with the tuner whether my AFM will maxed out with the 2535/PFC combo or whether he can get around the AFM issue.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
