  • Replies 134
Posted Images
Spoke to Bosch Australia today.
'Apparently' they have ZERO stock, Bosch Germany where the Z32's are manufactured have had a problem of some kind halting production.
I can get a very limited number of AFM's BUT no where near the 31 that we need at the moment. I have been told to call back every 2 days as it shouldn't be too long at all.
I'll make a few more calls tomorrow and see if I can scab some from various places around aus to make up the numbers.
Obviously I won't send out deposit details yet..
Sorry ppls, if your keen you may have to wait a little longer. :S
Its been a slow day today, many many phone calls. :S
I was unable to find a wharehouse that had any z32 airflow meters.
I'm expecting a call from Bosch tomorrow, I will know where I stand with regards to a time frame then.
Please bear with me as the group buy will definitely be going through.
WHEN is in the hands of Bosch Germany.
Aparently they are a bit scarce at the moment... I bought one less than a month ago from Petroject in Vic.. they said a number came in to the country from Germany, and they were only allocated 2 units of 10 that they requested. I got the last one they had in stock :P
They are indeed scarce.. :(
Bosch Australia have 20 items coming in. They won't be able to supply us with the required number of airflow meters until May. :D
Sorry for the hassle peoples. Early January the airflow meters were available, a production issue occured resulting in no AFM's. :P
I will PM every one as we approach the time and see if your still interested in an AFM and create a new group buy.
For those in desperate need for a Z32 (VG30DETT) airflow meter APC appears to have them listed at $360 which is a pretty good price.
http://www.apc-racing.com/browse.asp?cat=14&car=11
is this group buy still going on?
z32 fits r32 gtst right?
They will fit the 32 gts-t with the tomei plug or a plug from a vl but it will not work without a piggy back ecu or aftermarket of some sort.
Greg
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
