  • 4 weeks later...
  • Replies 134
Posted Images
I've updated the origional Post.
I received a call early this morning.
Due to a shortage of supply the group buy will not go ahead until....... Bosch are ready. :bunny:
According to Bosch: At some stage there was a manufacturing problem that caused a lot of back orders.
They estimated they would be in surplus by the 1st of May.
Its now the 1st of May and they still have backorders.
Z32 Airflow meters are available in small numbers around various suppliers for the full price but as I said... In small numbers. The supply to these suppliers obviously takes priority over our group buy.
To my surprise, I received a call early this morning, Bosch have now pushed the date to the 1st of July.
Either way, 'eventually' our group buy will go ahead.
For a new afm that you don' t have to worry about for another 10years its an awesome price.
  • 1 month later...
