Item: many, clutches, mafs, strut braces, turbos, actuators, cam gears etc
http://www.japboyz.com/specials.htm
Item Condition: varies
Reason for Selling: garage cleanout
Contact Details:
Contact Sasha.
Please enquire via telephone: 0411 424 393
popped on website for ease of managing whats sold and whats not.
All these price have been reduced. Gotta sell.
Call for serious enquires
https://www.sau.com.au/forums/topic/102343-gtr-parts-for-sale/
do you have or can you get the snorkel part of the air in take on the gtr if you can please pm me and ill arange to get it from you thanks
thanks david.
Hi all,
regards a couple of PMs - All Parts are in SYDNEY.
please phone 0411 424 393 if you have serious enquiry.
if you need to email : [email protected]
thanks
Hi Sasha,
I need the metal intercooler pipe and bracket on the passenger side that goes between the rubber hoses connecting the Twin Turbo pipe to the intercooler.
I also need a metal bodied R33 GTR power steering resevoir. (bolts to the left shock tower)
Can you help?
Stan
[email protected]
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
