Gday, heading to my first car track day this weekend at wakefield saturday...
Anyone else going to this?
Never been to wakefield, never been in a car either so hoping it's gonna be alright and not too busy...
Anyone been to their no limits days? any good bad comments? specially going on weekend?
https://www.sau.com.au/forums/topic/102460-wakefield-track-day-sat-21st-jan/
They are good. I'm going tomorrow if anyone is keen to join me.
$40 Wakefield licence, $90 for the day. Passengers allowed but they pay the same as drivers.
Weekends are busier for sure but you will still get plenty of track time. There have been heaps on there lately so it shouldn't be too crowded for you.
Make sure you prepare your car beforehand and keep your eye out for fellow skyliners to talk to.
I wrote this ages ago which you may find useful.
http://www.skylinesaustralia.com/forums/in...pe=post&id=2785
would much prefer a weekday but with a new job it makes it hard :'(
thanks for the link, a nice read... i'm sure it's very similar to the bike days...
just wondering what it's like with other cars out there and passing and stuff.
they say passing only on the straight... what happens if some1's up your ass the whole time or visa versa... would suck to have to spend the lap following them/following you...
either way should be great!
Burnsey
People are usually very polite about it. Keep an eye out for the faster cars before you get on the track and then move over and wave them past when they come up behind you. Hopefully others will do the same for you.
Watch out for wankers in evos diving under you on brakes in the kink at the end of the straight and stay away from all the S15's. They can't drive :D
Wakefield is the first track i drove on (bathurst doesnt count) and its really good for first timers
Abo Bob is exactly right about the other cars
You will have heaps of fun - id go if my CV didnt explode on friday night
I'm going down oon sat with a mate in another r33 gtst been to a couple before I would highly recommend it - good value and wakefield is the best track for your first time (plenty a space rond the track for mistakes - thats why I'm going there again).
hahaha...no chance of going for me! last time i went was on the penzoil day out ...and blew my engine..it has been confirmed..BLOW ENGINE PEOPLE!..let me just warn everyone....dont go unless you are willing to live with the consequesnses...haha...me?....rebuild i hope :O think positive! woooossaaaaa
Wayne ended up going to both to wakefield as well as Eatern Creek had a good day with a couple of mates but very hot could only do 2 laps slightly hard before water temp was above a hundred need that oil cooler. EC is a heaps better track especially at the end after learning some lines following Paul around.
I think i may have seen you out there reedy.
I was the white series 1.5 with it's hood up for most of the day in the 2nd row of garages...
after the first session, found out my oil line to the turbo sprung a leak... so rest of the day was passengering in my mates s15. had one drive of his car and got ~1.16 hand timed i think... not too bad for a car i'd never driven....
Getting the problem sorted and new brake fluid for next time!
hopefully get some decent consistant times...
Hey Abo bob, what mods are you running while getting those sorts of times??
Thanks
Burnsey
Hey Reedy, does your r33 have a FMIC or a stocky?
Maybe whack in a twin pass rad + a oil cooler, should cool things down a bit.
I've got a track day at Wakefield in a couple of weeks in the DatNats '06. B)
Ports i've got a FMIC, looking at a couple oil coolers bellow believe I need a thermastat as well? Whats a twin pass radiator?
http://www.skylinesaustralia.com/forums/in...howtopic=101031
http://www.skylinesaustralia.com/forums/in...showtopic=81255
Sometimes a FMIC can restrict airflow into rad.
I found this info at UAS:
TWIN PASS MEANING WATER FLOWS IN AT THE TOP, ACROSS, THEN BACK THROUGH THE BOTTOM OF THE CORE, SO IT IS IN AND OUT ON THE SAME SIDE WITH A DIVIDER IN THE MIDDLE OF THE DRIVERS SIDE TANK. THE AIR GETS TWO GOES AT COOLING THE WATER. WE HAVE DONE TESTS THAT PROVE THIS COOLS BETTER, EVEN COMPARING TO A THICKER AFTERMARKET SINGLE-PASS CORE RADIATOR. THIS UNIT HAS MOUNTING BOSSES FOR THE FAN SHROUD AND A RIDGE AT THE TOP TO LOCATE THE FACTORY ALLOY FORWARD PLATE.
A BOOK BY THE NAME OF "FORCED INDUCTION PERFORMANCE TUNING" STATES:
"A TWO-PASS RADIATOR WILL DUMP 15-20% MORE HEAT THAN AN OTHERWISE IDENTICAL CONVENTIONAL SINGLE-PASS RADIATOR"
These are used on most V8 supercars.
So I guess you should give the 'cardy man' a call, aka J Penlington. :PBJ:
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
