4+6 Point 3" Harnesses - Fai Approved - $329
1. abcent - Black, 4 Point Motorquality harness - CONFIRMED
2. Rowdyr32 - Black or Red, 6 point Motorquality harness - CONFIRMED
3. KamikazeR33 - Black, 4 Point Motorquality harness - CONFIRMED
4. 9krpm - Black, 6 Point Motorquality harness - CONFIRMED
5. Bass Junky - Black, 4 Point Motorquality harness - CONFIRMED
6. gadg/ Let Me Drive - Black, 4 Point Motorquality harness - CONFIRMED
Hi Guys,
Meridian Motorsport is able to offer the Skylines Australia the following group buy special on the MotorQuality brand 4 & 6 point, 3” race harness.
The MotorQuality harnesses are manufactured from high quality Italian components & feature a traditional aircraft style rotary turnbuckle with offset tangs on top webbing for increased driver comfort.
They are available in red, blue & black.
All harnesses will have a 5 year FIA life
The recommended retail for the 4 point 3” harness is $399 & $435 for the 6 point.
Group buy price of $329 for the 4 point & $365 for the 6 point harness -
Minimum group purchase of 5 harnesses, colors to be specified at order.
I will take control of this group buy and at this stage please only post if you are want one or have questions (no other crap posts please) Please post colour required. We will not do anything till we have a group of at least five. If we get more, then I will go back to Meridian for a cheaper price.
Also ERG Harnesses are avaliable. I believe these come out of the same factory as Sparco ones and are an exact copy.
4 point retail $359, group buy $324
6 point retail $399, group buy $360
Thanks, Chris.
put me down for a Black MotorQuality 4 point harness!
might be a stupid question, but do they come with a "how to install" guide, want to know where its best to anchor them from? ie/ the rear parcel shelf?
Not sure which one would be the best one to go with. I would think that their isn't going to be much difference in quality at all. Both have 5 years FIA stadards attached. I have a ERG one and it's good.
They are pretty easy to install. They just come with some eyelets that are threaded the same as you existing seatbelt bolts. So you just unscrew the existing seat belt anchor bolts and screw these in as a replacement. Then it's just a case of hooking the ends of each belt to the eylets. Which is a clip on/off belay setup similar to rock climbing gear. The top harness belts attach to the rear passenger seat bolts between your rear seats. So the beauty of the setup is that you can still keep your exising belts and have no problems removing and re-installing at any time. A few of the vic guys have these already, so we can show you how we did ours. This is the case with the four point setup in a standard street trip vehicle anyway. Obviously if you were running a cage, or other strut bars, or 6-point there is additional work and you should probably consult a CAMS scrutineer at a minimum.
The other good thing about these are they bolt into the standard ADR approved seat belt mounts, so you know these wont just let go, and have been crash tested.
Just spoke to tony before. He said the erg harnesses are made in an asia country ( I can't remember which one) and he recomended the motorquality harnesses since the are made in italy.
Chris put me down for a 6 point harness by motorquality. He said there are heaps coming. Can I specify colour later. Can't choose between black (inconspicous?) or red for rice.
Those pics dom't show how:
Could someone post these pics because I'm interested.
No go on those photos?
See here: http://www.skylinesaustralia.com/forums/in...0entry1882711
Post # 49 - Matt has provided photo's of how most of us have setup our harnesses.
My suggestion is to seek expert advise from a qualified CAMS scrutineer (or Meridian) as to your individual setup, as safety is of the highest importance. Many people have raised valid questions to the validity of some installation methods. I personally will stick with the installation setup as shown in the photo's, as this works for me.
These racing harnesses are all FIA approved. No 4/6 point harness are ADR or dotars approved for use in a street car – legally you have to use your lap sash on the street – no exceptions. You can have the 4/6 point fitted to the car, but legally you have to be using the lap sash as well.
don't suppose these are ADR approved?
We need one more person for this group buy to go ahead.
As soon as we get a fifth person we will go ahead. If your sure you want one pete let me know and we can go ahead.
Has everyone else got funds and still commited? Please PM me if your ready to go. Once I have five PM's I will reply with account details. If you require shipping please let me know that your are not in Victoria. PM me with your address and I will calculate shipping.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
