After watching shows such as the fast and the furious, during the main race you see the green eclipse has a indash monitor which shows danger to manifold and engine readouts
now i have a indash monitor and i wondered how hard it would be to get software or something to show stats on the screen such as fuel, speed, rpm's etc.
i already have an apexi rsm which does all this , but using a colour monitor im thinkin i could go one step better, has anyone done this yet or know anything about it
thanks
https://www.sau.com.au/forums/topic/102605-monitor-preformance/
Why not go one better and rig your car up like the kit car in Knight Rider??? Make it have a voice and it can tell you whats happening...
As for the other thing, i'm sure its possible, but if you have an RSM anyway, why bother with the expense
thanks
Yep got to watch for danger to your intake manifold it causes your passenger side floor to fall out :P .
34 GTR has a indash monitor for injectors, boost, g-forces ect.
cheers
MOTEC will give you that mate. Hook it up to your screen or Laptop
have u got any more detail about this, like model name or number or something,
im not sayin im gonna do it, depends more on the cost and what i can monitor.
oh yeah and i wanna watch the welds on the intake :lol: :lol: :lol:
The MoTeC can monitor anything you can imagine.
Im sure if you put a temp sensor on the welds, it will monitor those as well :lol:
and because im such i nice person here you go:
CAMP (Computerized Automobile Multi Player) (more)
The HKS CAMP offers drivers the ability to view engine vitals such as RPM, speed, and gas mileage by integrating into a vehicle’s Audio/Video display screen (not included). With the addition of the CAMP Junction box and optional sensors other engine functions can be monitored (boost, pressure and temperature).
Analog Display - The analog display can indicate speed, RPM, gas mileage, fuel consumption and injector opening percentage. The CAMP includes peak data memorization and allows the scale to adjust according to current driving conditions.
Digital Display - The bar graphs along with digital numbers indicate multiple data to simultaneously observe entire vehicle conditions.
Alarm Feature - This allows the user to set a designated limit for each data. CAMP will inform the user by sound and graph if any data passes the limit.
I second the consult software. $100 for a cable, hook it up to your carpc or laptop, and use the free software. This will show you everything the consult cable puts out.
Newkleer is making a new consult software, so I recken it'll be the goods!
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
