Hey guys,
as im going with a purple theme in my car, the dash seats etc. i now want to do the door inserts as well.
Ive read a guide on removing the door trim, but how hard is it to remove the inserts, can they be unplugged/unscrew or is it a sealed peice ?
also if anyone has done it can they post a pic..
thanks DAZ
https://www.sau.com.au/forums/topic/102878-retrim-r33-door-inserts/
mate, i'm in the same situation, well i stripped the car for painting so the trims are off but i wanna do something to them, just not sure what, mines a r33 4 door, i want to build doors pods for speakers and stuff just not sure how to tackle it, pics would be great people
i pulle of the door trim and its one piece so the inserts cant be unclipped...does anyone know if the inserts maybe double sided taped on, coz i dont wanna rip tehm off and find i cant get them back on and damage the door trim
  • 1 month later...
well since the initial first post i brought both the driver and passenger door trims. Now teh inserts are moulded part of the door, os you cannot unclipi them like most cars, so ive got a few ideas on how to do it ..so once i work it out ill post up a DIY
i had this problem with my last car. Thought for ages about the best way to do it and came up with the idea of
thin mdf sheet (<5mm) cut to the shape of the door trim insert but maybe 3mm or so bigger all round. Put some bolts in so they fit pretty much flush with the mdf (and use glue/bog or something to hold them in place)
To this add a thin foam underlay, then stretch and staple/contact glue vinyl around it.
Then drill a few holes in the existing door trim, for the threads of the bolts to go thru, and screw the nuts on from behind the trim.
Would have looked ok if i'd spent more time on it, ended up just using a sheet of vinyl to cover the whole door trim cos that way the standard trim was totally intact underneath and i could go back at any stage if it looked ghey..
heres a pic:
  • 2 years later...
I know the topic is old, but I'm trying to change door trim inserts in R32. Same as in R33 door trim inserts cant be removed from trim as they are just part of it. So I peeled of the old ones, got some vinyl and spray adhesive from spotlight and cut out the new ones. But sticking them onto the door trim is a real bitch. It doesnt perfectly allign around edges and it started peeling of withing days. After spray adhesive I tried sticking them with uhu all-purpose glue, same shit. For some reason not even super-glue wont hold it on the edges.
Its really crap that door trims inserts cant just be removed like in any other car... there must be another way because I think myself and several other people have proven that sticking a piece of fabric over the door trim doesnt work. There is no way.
I'm thinking about taking a small electric saw and cutting out the door trim insert and then get it retrimmed properly. But i dont think that would be such a good idea...
Anyone managed to get door trims right here and would like to share it with us?
Ha i peeled my factory ones off then thought gosh darn how am i going to get this back on properly. Went to spotlight... bought some velvet looking material... traced it out exactly the same as the old one... used some "Septone Spray Adhesive" from supercheap and masked up all the edges... sprayed the trim and the material i was going to place on there... left it for 5 mins as the directions on the can say... then placed it on and used a bread and butter knife to carefully push it down the edges and then left it to dry.
It has a LOT to do with what material you are using. I tried it with vinyl. Terrible... I didn't even bother letting it dry as i knew it was going to look like sh!t. Best to use something thin like a felt/velvet material that has some slight stretch in it... vinyl or thicker materials are always going to want to flatten out.
I considered cutting the trim out and glueing the new piece around it and then somehow attaching it back to the trim... fibreglassing perhaps... but more trouble than it's worth and the more cutting you do the more chance of *ucking it up you have.
Cheers.
g'day only just found this post but thought i'd share some pics (i hate topics with no pics :happy: ).
I was like all of you and tried different ways but then decided to get it done professionally when i had my seats done at the same time. Also 'teamplasma' wanted to build door pods, well i guess you've done so by now but here's my fibreglass ones anyways.
It came back a treat and looks fantastic! Andrew from Striaght Line Motor Trimming will help you out: 3/6 Holloway Drive, Bayswater 9762 3773 www.straightline.com.au
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
