I was looking under my car tonight, and noticed I have 2 mufflers.
I wouldn't mind my exhaust being a little louder, so if I took the middle muffler out and left the back one, would it sound better?
What would removing it do to the exhaust note?
Cheers :rolleyes:
https://www.sau.com.au/forums/topic/10290-exhaust-with-2-mufflers/
My exhaust goes something like this.
cat - hotdog resonator - box muffler - polished jobbie at the back.
All this to keep the dB at a safe EPA level. All components are straight through design so there is little difference in power (about 5-6rwkw) between one or all three mufflers.
Mind you, if you can handle the droning on the freeway at 110km/hr nothing sounds better than a straight pipe with single muffler on the tail.
Z.
i just got my middle muffler and resonator removed
and replaced with 3 inch piping from the cat straight to my trust muffler
it sounds awesome , a much louder tone on idle and acceleration sounds like a beast! no droning which i thought there would be but it surprised me! next on my list hehehehehe dump and highflow cat hehee and the cheekiness of a Cat-Out pipe hehe
I removed the resonator from my car not long ago. Makes the car sound a little louder but i notice more backfiring when backing off the throttle every now n then. Does make it sound neater tho, but not hugely noticeable... If you want it to be loud run a 3" system no resonator into a straight through muffler, then it will houl.
for mine ... the long exhaust pipe splits into 2 smaller pipes just before going into the big muffler at the back ... does anyone know if this is a good or bad one?? its got that jasma sign on it too so it must be certified ... its a very quiet exhaust ... can hardly hear it but its 3" pipe down the middle ... any good??
Jasma is a Blitz sub-ordinate company, kind of like Lightning Audio is a Rockford Fosgate product simply marketed as a different company, so your hard-earned dollars end up in the same hands.
My R33 GTS-t came to Australia with this exhaust already fitted (like most), and it is 3" in diameter turbo back, however it is very quiet, so I am of the assumption it is restrictive.
If your's is the same, and you're serious about kw, do what I'm doing - UPGRADE!
Lambros Hi-Tech Mufflers in Sydney claim 25rwkw from their 3" stainless turbo back system - that's impressive in anyone's language. They claim that it's not too bad on the ears, either.
Cost is around $2100 fitted in 2 1/2 hours.
Worth a thought...
What the.................. :lol: :lol: :lol: :lol: :lol: :lol:
I have no idea where you heard that, or what clueless hippy told you that, but that's so completely wrong I actually laughed out loud :P
JASMA (Japanese Automobile Sports Muffler Association) is a Japanese Association that "certifies" exhausts made by Japanese companies that conform to their very strict noise level guidelines.
For example, I have a JASMA apporved C-West exhaust.
Case Study: HKS Super Dragers are JASMA approved, but the HKS Drager 2 only conforms to JASMA noise limits with the restrictor in. The HKS Hiper doesn't conform to JASMA noise limits at all!!! :bahaha: :bahaha: :bahaha:
I hope that clears up any misconceptions you have about those pretty "JASMA" plates that are found on some Japanese exhausts...
First I put in a 3"cat Back, resonator with 5" tip. Droned and was much louder $400
Second I had the front half done with 2nd Hand Hi-Flow cat. No Drone but still $450
The back half of the cat crapped its self so I had it gutted (for now, no cost). Drone's again, and is louder still.
Don't mind the sound.........but starting to shit me when I am not upping it.
Small increase noticed with cat back.
Bigger increase with Turbo back.
Even bigger still with the way it is now.
Was looking at one of those Spiral resonator's next just to quiet it down a bit.
Car sounds louder inside than outside.
The less restriction the better.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
