  • Replies 717
11th aye....thats my bday...myte get fudged... but that be night time ;)
Me too! I vote 11th, then, and Paul and Stacey can "donate" one 2530 each to me and E-Lu_SHuN, to throw on the Stagea and R34 respectively! :)
Yeah, I might come down for this - will try and allocate some finances to get the wagon on the rollers to see how much (or how little?) it puts out. UAS is less than 15mins from home anyway.
Nick T.
It will be 11 March. I'm going to make another official thread sson but haven't got around to it yet.
Lee - There are no power to weight advantages on the dyno mate :P:D
Tommy - you better be there. You too Morgs.
Blitz - with new turbo?
