Any pics of my car?
How did you go BU5TER? Did your poor little GTS-t make all the mighty GT-Rs quiver in their boots? Would have been impressive to see it run, especially the howl of that screamer pipe! And in front of media crew!
  • Replies 717
He rawked!
Brett was there very earlyand made 372kW with his de-stroked RB18DET.
:laugh:
That's a super effort. I must have had my eyes closed though, because I was there before the first car went on.
Did Ben strap it down?
hmmm...1.8Litres from an RB30. That means a bit less than 52mm stroke. Can't be much meat left in the crank pins if it's been offset ground that much (in the wrong direction :D ).
Could have super long rods in an RB30 block though...must be good for a gazillion revs! :no:
Edited by Mik
Just wanted to say thanks to Adam and UAS for organising and running the day yesterday - top work!
Very surprised to win R33 GTST w/aftermarket turb with 286.6rwkw (which is just about spot on what it did on MRC's dyno last year), but I'll take it :no:
Overall, a pretty good day! :D
I think there may have been some coercion involved there. I swear i saw u slip ben a bundle of notes after the 270kw run!! :laugh:
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
