Hey everyone
I wasn't sure where to post this, but since im from vic, i thought i'd ask someone from vic. lol. Im looking at buying an aftermarket fuel pump for my r33 gtst which needs to be able to handle a fair amount of power. I was recommended by autobarn to use a bosch 044. I don't know much about fuel pumps. i believe these are external? I've been told by friends that these can be quite noisy. Could someone explain wat that means. Also last night i was told that i would be better off getting a Walbro fuel pump. Are these internal or external? Wats the best thing for me to do. I didn't wanna spend more than probably $250. Just not sure the best option to go for. Any help would be very much appreciated.
Cheers
Guesty
https://www.sau.com.au/forums/topic/103369-fuel-pump-question/
044 is external. unless you're intending to output over 350kw at the wheels i would stick with an internal bosch 040, which you can buy for under $250. Walbro's are shit dont bother.
any particular reason why you say walbro pumps are shit?
actually...i brought a bosch 040 for my r33gtst, the workshop told me to get rid of it, hard 2 put in, surges around corners and to put in a walbro...said there much better...this was from a respected performance shop...havin already brought my pump i decided to go my own way and put the 040 in.....works fine, lil noisy
Walbro's are good in respect to fitting and noise but definately not reliable....I have 2 cases which burnt out with in 6 months
Bosch 040 is good and reliable, little harder to fit and probably wont sit far down in the tank...so if your low in fuel you might get surges
unreliable, know of 2 people who've had a walbro "500hp" pump fail on them and they were supposedly genuine pumps.
the walbro pump is physically smaller than the bosch 040. the bosch IS a prick to install, but remember that if you go for an external pump you will also need a lifter pump inside your tank regardless... certainly not a $250 excercise.
the walbro's are rated at 15volts in the r33 they only run at 12volts so they never run at their optimum charge, hence "they're crap" run a 15volt direct circuit to them and they should be OK.
skyline r33 gtr pump should be fine for your requirements and is a direct fit. the bosch is only noisy if installed incorrectly. normally it should be quiet
Edited by sarahB
hey GuestyR33...
i've got a Bosch 040 for sale if you're leaning in that direction - never got round to fitting it and i don't need it atm. here's the link to my post:
http://www.skylinesaustralia.com/forums/in...opic=100789&hl=
/end shameless plug :)
Well from the sounds of it
Im leaning towards the Bosch.
Fitting hassles are neither here no there.
Wat else do i require if i fit say an 040 or 044
When u say there noisy, wat do u mean. Wat kind of sound, is it loud. Can u here from cabin. I've just never seen one of these installed.
Thanks everyone for your speedy replies.
Been a great help.
I have a Bosch 044 external installed in the boot and it is pretty damn loud, but i have gotten accustomed to the sound :lol:
Ever hear speaker noise from a stereo system with earthing issues or rca's running along side the power cables? Well the sound is similar to that but deeper and a little louder. Definately heard inside cabin, and over a loud exhaust.
The Bosch 040 are alot quieter, and can only be generally heard while primming the engine b4 start-up.
