I have recently bought a R32GTR & when left idling for a short period of time it blows blue smoke. Although under load it doesnt seem to blow any smoke. Does anyone have any ideas as to what it might be????
Any help would be great thanks :)
https://www.sau.com.au/forums/topic/103388-r32-gtr-blowing-blue-smoke-on-idle/
Could be a range of things, blue smoke usually represents oil, if i was to guess sounds like a turbo's on it's way out. My dad said somthing abotu the valve guides or somthing aswell, turbo would be a common problem, how many K's it done??? And is it boosting at factory pressier or has it been wound up.
Michael
how long do u have to leave it idling????
could be rings !!
or turbos
Blue smoke is FOR SURE oil!
The best thing to do is trouble shoot and you can start by doing a compression/leak down test across all 6 cylinders. If when you remove the plugs there's oil on them.....problem. ;)
Check that all your gaskets are tight and dry.
Check for shaft play on your turbo.
Now if it's only happening at idle then there's a good chance it's your motor not your turbo. I had the oppisite problem on my ka-t set up in my 240. It idled fine but under load in boost...blue/white smoke. That turned out to be blown oil seals in the turbo. I would have someone follow behind you and see if there's smoke while your boosting. Don't go nuts but you need to know.
These are the easiest methods of trouble shooting and should narrow down exactly what it is.
Good luck man and I hope it's nothing serious.
Cheers B)
Could be from a number of places where oil can be pulled from eg. turbos, valve seals, oil rings.
I would start my checking the inlet of the turbos to see if there is oil coming from the inlet side of the turbos.
Basically, get ready to open your wallet.
where are you located?
ive noticed a few of your posts are in regard to problems youve got with the new car.
did you get it checked over before you bought it?
this GTR you bought seems more like a lemon than a yellow submarine :P
Edited by SLIPPERY VL
If when you remove the plugs there's oil on them.....problem. :unsure:
I changed plugs on a family member's Toyota a few weeks ago and one of the plugs came out covered in engine oil. Is this blown rings? I'm keen to learn more, I meant to post but forgot all about it! :D
Cheers
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
