Probably. I've seen articles that describe "clutch is to the drivetrain as a fuse is to any electrical component". So, as you start putting too much torque through the clutch, it will eventually reach a point where the clutch will slip, thus reducing the torque delivered to the other components of the drive train.
If you uprate a fuse, you increase the risk of damaging the electrical component(s) on that fuse's circuit. Similarly, if you upgrade the strength of the clutch, then the torque from the engine starts looking for the next "weakest link", and this will likely be a gear, either in the diff or in the gearbox.
yes....
Running a button.. or twin plate definitely puts more strain as there is a much firmer clamping action. This is obviously good for a firm mating action, but like Elk is saying above the energy has to be transferred through to something, usually the rest of the drive train. If that isn't up to it, snap.
In some cases, I tend to think having a clutch that slips slightly is probably better for the long-term health of the gearbox, as there is a little bit of give.
Obviously there gets to a point where you need something quite heavy duty (twin, etc) but its not always a good idea to put the heaviest clutch in you can get.
Well i have a R34GTT gearbox, the twin plate im getting has a 920kg pressure plate, ive seen cheaper aftermaket clutches that have heavier, the box only has around 40,000 kms on it.. Do you know this will do any damage?
Sure, but like everything 10% of the damage will be because of the type of clutch and 90% will be the way you drive it.
A heavy clutch wont f**k the box on it's own. If it has a heavy pressure plate it may bend the clutch fork, snap the pivot, or cause premature failure of the hydraulics.
If it's unsprung it may damage the gear faces and eccessively wear the bearings if you have a lumpy idle.
If it's a puck type clutch it will wear the stock flywheel more than an organic (not that you have this problem as you get a new flywheel)
So unlike the other guys, i'm willing to say you won't kill your diff or box solely because you've installed a twin plate. If you've installed a twinplate behind a 400kw engine then it's a different story as now you can transfer all that torque and tear the teeth of 3rd gear :D
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
