got the following for sale.
RB20det injectors $100 set of 6 or $20 each.
rb20 coil 'cover' nissan badge removed. $20
R32 GTR/GTS4 front hubs, wishbone and upper arms $200 pair. ono
lower arms for above $40 pair.
front swaybar $25.
front subframe/crossmember - gtr/gts4 $100
rear subframe/crossmember gtr/gts4 ( subframe bushes removed) $200
prices plus post etc.
Stephen - PM me if interested.
https://www.sau.com.au/forums/topic/103429-r32-and-rb20-det-parts-for-sale/
how much to post the coil cover to wa champ?
from canberra to perth wa is about $12, let me know.
It weighs 600 gms which just puts it into the next weight bracket.
Forgot to add that it is the cover from a rb20det silver top .
Let me know if you want it.
Stephen
Edited by gts4diehard
  • 3 years later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
