seriously someone needs to buy this, its in the madest condition, i know ive gone and looked at it. the pics dont do it justice you have to go see for yourself. and before anyone says "why dont you buy it then?".... i already bought another cefiro from him and was very happy with it, top bloke as well to deal. so yea if you're serious about buying a clean as ceffy go check it out, its definately worth looking at and buying
Thanks mate, appreciate the kind words.
Yep i'd agree with that, sorry guys im not the best photographer out there, maybe i should take some new photos? :P
it does look a lot better in real lifE!
Needs to sell as soon as possible!
Saw the cefiro at the BP the other day.. Clean as.. and GTR kit looks better in real life.
  • 3 weeks later...
