try this mob... www.speedhut.com they're willing to make em if you send em a gauge to base one on, and you can get 20 people to buy em. I asked em, and they agreed to use cyberstork templates instead of gauges. however they count the GTSt's n GTR's as seperate designs.
  • Replies 130
yeah the holes where the gauges sit on the cluster are different. So you can't place a GTR EL cluster onto a GTSt cluster.
Also if you make holes for both the EL will look bad because of random holes in the center of the RPM gauge.
Has anyone got a spare set of dial faces from a R32 GTS-t and an R32 GT-R?
LW.
BUMP.
I have posted a request in the WTB section. If I can get the dial faces organised I will contact SpeedHut and arrange for them to be shipped so we can get a group buy going.
Are any R33 guys interested?
Thread is here (or see sig): http://www.skylinesaustralia.com/forums/sh...ead.php?t=40141
Cheers,
Lucien.
Just to add to my previous post, my thinking is this: we get all the relevent dials to them, then get them to setup relevant pages on their model development section (http://www.speedhut.com/15orders.asp). That way we don't have to worry about collecting money and converting it, etc, etc.
Once the pages are up we can setup (ie. advertise) the group buy through SAU and SDU. Only problem I see is shipping -- it might be easier (read: cheaper) to get them all shipped in one batch to Australia and then redistribute rather than having SpeedHut send invidual packages.
Thoughts/comments/suggestions?
LW.
sorry if this has been asked before...
but can you get the EL gauges for a R34 GTT?
Well we could always send some R34 gauge faces to SpeedHut with the R32 GT-R ones, but I am not sure there would be enough interested. Having said that, there are a lot more R34 GT-Ts in New Zealand, so the SDU guys might be able to make up the numbers.
The only problem would be getting a set of the dial faces.... Any suggestions? :)
LW.
hmm maybe I could send the busted ones that one of my mates has at his spare parts shop lol.
/me looks at the R34 GTt gauge he was tryin to fit on his R32... hmmm
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
