Just a curiosity question (would ask mechanic but he is on holidays)...
If I am fitting a dual entry fuel rail, and the pump setup includes a Bosch 040 in tank and two external 044's, how are they plumbed up to the rail? One line running from each 044 to each end of the fuel rail and relief from the middle?
Are there any better or alternative ways of doing this?
Thanks :ban:
https://www.sau.com.au/forums/topic/103975-fuel-rail-and-fuel-pumps/
At the risk of asking a stupid question (There are no stupid questions, only stupid people :ban: ) why do you want to fit up two feeds to the fuel rail? When you use pumps in parallel (other than positive displacement pumps) you get a very small gain in flow for a huge gain in cost/power consumption etc.
Mostly fuel setup are as in the photo - with two pumps picking up from the tank & pumping to another small tank which is then always full. The third pump picks up from there & keeps the fuel rail pressurisedl at all times.
Edited by djr81
Hi,
Thats why I am asking, as im not sure how it works. Currently there is the standard GTR pump in tank lifting to a surge tank, with a single 044 from the surge tank to the standard fuel rail.
Have since bought a HKS dual entry fuel rail and some pumps, my thinking was the 040 in tank pumping to the surge tank and the twin 044's pumping from the surge tank. Just not quite sure how they connect up to the fuel rail... do you join the two feeds together then split them again and feed it in to each end of the rail, do you keep them seperate from the 044's into each end of the rail?
Just trying to learn a bit, as for actual fitting, thats what I am paying the mechanic for :ban:
do not go too overboard with the fuel unless it is an all out race/drag car as otherwise you will find you are pumping a lot of fuel around unnessesarily. this has the negative effect of heating the fuel (as it passes through the rail/engine bay) and eventually you have a whole tank full of hot fuel. which can hurt performance.
if it was me i would join the two pumps to a common line (possibly with a check valve after the outlet of each pump) then when that single line gets to the engine bay you split it in two and run a feed at each end and the reg/return from the middle. will you really need 3 044 pumps though? what size injectors are we talking about?
Injectors are currently 700cc, probably need to go up in size as they will be too small.
Any other suggestions on pumping the fuel around for this power level? Bits and pieces I have to work with are: standard fuel rail, bosch 040, two bosch 044's, surge tank, hks twin entry fuel rail, standard fpr, sard fpr (the big RJ one).
i don't think you will need that much pumping power to supply 700cc injectors. surge tank is definately a good idea (and make a large one if you are going to be doing extended WOT driving). sard fuel reg is a good idea too, and i really like the idea of twin feed rails as i'm sure you get much more even distribution of fuel throughout the 6 ports. some larger fuel lines could be a good idea too. i would think you could just use the GTR pump to fill the surge tank then use a single 044 to pump fuel to the engine bay then have a split with the two lines heading to each end of the rail, run the feed for the reg off the middle and return the fuel from the reg to the surge tank.
The numbers tell the story.............
700 cc's X 6 = 4.2 litres per minute = 252 litres per hour
At 13.8 volts a single 044 will move 330 litres per hour at 73.5 PSI
So it will support 6 X 900 cc injectors at 2.4 bar boost with standard fuel pressure (36-38 psi)
So using 2 X 044's would lead to excessive fuel flow, even at 100% injector duty cycle. As BB quite rightly points out, that means hot fuel going around and around for no good reason.
:P cheers :D
cool, i might just do this with my twin entry rail, means i can run the Reg off the middle outlet.
Sydneykid YOU are a wealth of knowledge!
it;s the only smart way to run a twin entry rail. as far as i know that is the main advantage of a twin entry - more even flow to all injectors.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
