post-23484-1139116297.jpgpost-23484-1139116341.jpgpost-23484-1139116419.jpg1998 Black R34 GTT
5 speed manual,
80,000kms
Tommy Kiara front Bar
T Spoiler
HKS fully adjustable suspension
Pod Filter
HKS electronic boost control with display
Full HKS 3' exhaust from turbo back
tinted windows
Xenon headlights
Full sterio
$27,500
please call 0400 841 142
Car has 12 months rego
Edited by CHO50N
https://www.sau.com.au/forums/topic/103982-black-r34-gtt/
car was revered into by a ute which pushed the light back :D did not move the supports or anything, there is no damage to the front end at all or the rear.
only the light bracket broken.
could replace but when you do you really need to buy a pair to get them matching.
Please do not hesitate to call.
0400 841 142
Edited by CHO50N
https://www.sau.com.au/forums/topic/103982-black-r34-gtt/#findComment-1944706
I never thought i wanta a skyline Gtst or Gt-t again after i sold the R33 gts-t BUt this one has made me want it so hard core if i wasn't still on Suspen for 3 more months i'ld be taking this off whoever Buy it off him i'll make u a nice offer in a few months i was going to get a S15 BUT man this is sik :D
https://www.sau.com.au/forums/topic/103982-black-r34-gtt/#findComment-1970140
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
