  • Replies 58
Who else is stoked that this Thursday night Lost is back on the air!!!
Woot woot.
Whats in the hatch?
Will Walt be OK?
When will Jack and Kate get it on?
:( B
YEA! I'm really excited about the season return of LOST. Watched the first season 3 times now, still can't figure out what the go is.
Today on the radio they mentioned not to "get too attached to the characters" as they get killed off this season.
I just can't wait!!!
https://www.sau.com.au/forums/topic/103987-tv-lost/page/2/#findComment-1915181
the only thing that really lets this show down is the "aussies" which seem to have some weird westie crocodile dundee accent or brittish... which is weird... it would have been more realistic using the telstra call center staff in bangladesh then americans to act as aussies.. ie. bar staff... airport personel... cops.... its pretty poo
https://www.sau.com.au/forums/topic/103987-tv-lost/page/2/#findComment-1915283
2nded - it seems noone can get the aussie accent down pat - except us aussies!!!
https://www.sau.com.au/forums/topic/103987-tv-lost/page/2/#findComment-1915290
sooo f**kin true. americans cant get our accent right for shit lol
https://www.sau.com.au/forums/topic/103987-tv-lost/page/2/#findComment-1915952
Well Bec, were you satisfied?
Thought it was pretty good myself. Was a little thrown with the beginning, trying to work out who's flashback it'd be, but i guess that was the idea. Certainly mixed things up a bit.
The only thing I didn't like was the stadium scene, the idea of running up all those stairs gave me a stitch! :)
Opinions?
https://www.sau.com.au/forums/topic/103987-tv-lost/page/2/#findComment-1920629
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
