  • Replies 58
Who else is stoked that this Thursday night Lost is back on the air!!!
Woot woot.
Whats in the hatch?
Will Walt be OK?
When will Jack and Kate get it on?
:( B
YEA! I'm really excited about the season return of LOST. Watched the first season 3 times now, still can't figure out what the go is.
Today on the radio they mentioned not to "get too attached to the characters" as they get killed off this season.
I just can't wait!!!
https://www.sau.com.au/forums/topic/103987-tv-lost/page/2/#findComment-1915181
the only thing that really lets this show down is the "aussies" which seem to have some weird westie crocodile dundee accent or brittish... which is weird... it would have been more realistic using the telstra call center staff in bangladesh then americans to act as aussies.. ie. bar staff... airport personel... cops.... its pretty poo
https://www.sau.com.au/forums/topic/103987-tv-lost/page/2/#findComment-1915283
2nded - it seems noone can get the aussie accent down pat - except us aussies!!!
https://www.sau.com.au/forums/topic/103987-tv-lost/page/2/#findComment-1915290
sooo f**kin true. americans cant get our accent right for shit lol
https://www.sau.com.au/forums/topic/103987-tv-lost/page/2/#findComment-1915952
Well Bec, were you satisfied?
Thought it was pretty good myself. Was a little thrown with the beginning, trying to work out who's flashback it'd be, but i guess that was the idea. Certainly mixed things up a bit.
The only thing I didn't like was the stadium scene, the idea of running up all those stairs gave me a stitch! :)
Opinions?
https://www.sau.com.au/forums/topic/103987-tv-lost/page/2/#findComment-1920629
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
