  • Replies 306
Posted Images
lol sorry guys I'm runnin on a backlog of PM's since the forums were upgraded with people wanting all sorts of stuff fixed.
I'll reply to PM's from you guys and post up an updated payment recieved list asap.
I'll chuck both split and single manuals on the CD. Best idea evar!
hey funky whats the hold up... any idea when we shall recieve it or have u skipped the country with your small fortune :D
sorry for pissfarting around guys... just haven't had the time to finish em off. I'll be spending some time tomorrow morning finishing off the reauthoring of the PDF's (stupid japanese seller password protected all of em) and burning em onto CDs so I can send em off on Monday, or if I do em quick enough maybe even before the post office closes on Saturday.
Ian or Alex, if you want I can meet up with you somewhere around the Glen Waverley area and give you the CD's for the melbourne based guys so you can hand em out at the next meet. Otherwise I'll just post it out.
I suspect they won't be happy waiting to the next meet, so mail them out! :(
(I assume you had no trouble getting rid of the password? If not, send me a pm).
Ian
yeah I downloaded some password cracker thingamajiggy that got rid of it. The main delay was to get the full version of Acrobat 7.0 so I could reauthor the PDF's. All done now, unfortunately have to wait till Monday to mail em out.
Yeah, um, like... monday came....and so did tuesday...and wednesday, thursday and friday too......any news?
At this stage, id rather just come pick it up from your place. GW is on the way to uni for me every day so that would be easy enough. Otherwise, if it is actually sent this week, ill wait.
PM me your number or something. Thanks
They were sent middle of last week (using regular post) so it should arrive soon.
If there's anything specific in the meantime that you guys need urgently let me know and I'll post a screengrab.
hey funky i need abit of info or a screen grab if ya can, of the fuel pump relay (mounted on drivers side under kick panel) and wiring to the pump in the tank, i also think it runs to the engine ecu as well. its a black wire with a yellow stripe (its the main power to the fuel pump). let me know if u find any diagrams of relevance :thumbsup:
cheers
Edited by CruiseLiner
I normally get things in a day, but nothing has arrived. Can you check that you sent it to the address I PM'd you?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
