Hi Just wondering if anyone could help me out. I have just had an Apexi AVCR installed in my car :P and im running 14psi constantly, I have a 3'' turbo back exhaust, HKS pod, and a Blitz FMIC I havent had it Dyno tuned yet but was wondering what others with similar mods were running and how much can I run all day everyday safely, any help will be appreciated
https://www.sau.com.au/forums/topic/104505-safe-boost-level/
hhhhmmmmmm.........i've been running 14psi on my RB20 since bought it 6 months ago, haven't had any problems as yet (touchwood!) and not running a FMIC either . Is it true that std RB20 turbos can run a few more psi than RB25. I hope this is the case otherwise I'm gonna wind it down to 10psi.
yeah its only got the factory fmic, the size of a matchbox (well almost), probably good for stock boost, yeah should wind it back to 10psi, will do it tonight. FMIC upgrade is number 1 on my list anyway. :) Feels like I am losing top end power even on full boost though, time for a service and tune, big 100k service! ;)
i got mine dyno tuned, and it was set at max 10psi, but when i checked the ebc and look at the peak boost, it shows 0.86 bar = 12.4...somtimes its at .82 n i think i seen it at .9 b4...i dunno wast going on...any1 know how 2 use a blitz ebc?
What type of blitz ebc?
The SBC or SBC-id?
I used to own an SBC-iD, if setup in auto mode it had to be setup on a dyno other wise it would have a tendancy to spike a little.
Manual mode that uses a plain fixed duty cycle and gain was always rock solid but with the smaller turbo would tend to drop boost at the higher rpm, where as the auto mode would monitor boost levels and adjust duty cycle in order to force it to hold boost.
i seem 2 get diff boost peaks at diff gears....in 1st gearr i went to 5-6k and it peaked at 0.86, then i was doing 60 dropped to 3rd gear and got 2 5-6k and peaked at 0.72 which is a little over 10psi which is what it was set at....also was a cool nite last nite...
My Stagea is currently set at 12psi, with all the supporting mods. I never keep it held on 12psi boost for more than a sec or 2 - its the heat build up that destroys the ceramic exhaust wheel.
Ive got a spare RB25 turbo at home, so not too worried if she shags herself, but I dont think that'll happen due to my 1st comment above.
Talk about being right on the money, I went for cruise the same night after I left my post I and blew my f$%^&n turbo :( !...........Looks like im off the road for a while! What about the irony of reading the responses after blowing the turbo!....
hey i have a standard r33 gtst turbo for $400 :) pm me if interested
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
