  • Replies 97
Posted Images
like i said ive got plenty of time to spare, just say the word...
Cheers big ears... how do you have time to spare??? ha ha... kids, wooza AND a GTR- you must be a buisy man...
Appreciate it Stevo.
build a reeeeeeeealy big shed with a bar and it can be the SAU club house :P
Bar is on it's way... Casa del Xrated. Yeah!
Who's bringing the keg?
Back yard is big enough for quite a few cars, plus another 8-10 in the front yard... so yeah, why not.
I have what youre after :)
Yeah, but it's silver and only has one turbo... :nyaanyaa:
i can always find time in between my busy schedule..
All this XRATED talk, you better but some pics up of the old girl :thumbsup:
Hey Rob, how did you like the twin t4's on the 25 and manual? Was it just useless or useable enough?
Reason I ask, is I'm thinking about twin T67 8cm's instead of twin td06 L2's. It's a pretty big set up, but I'm loving single t67 in the shitter atm.
What do people think? twin t67's or twin L2's???
twin l2s wouldn't be much less power :ph34r: , you should take your 'shitter' out on the track at pd3 , so you can take me for a run in it , i'm pretty curious what the t67 is like on a 25 , if i keep my 34 it's the most likely turbo to end up on it atm :whistling:
The t67 on the 25 was perfect!
The 3lt lump that's in it now... more torque, but just dosn't feel right!
I'd really like to try a L2 on the current combo for a comparison.
The thing was useless.
Wouldnt even come on boost in 5th, too big.
The twins would have been great with the auto and a 6000 stall. lol. They had less response than the T51.
But would be fine with a big shot of gas :yes:
Edited by WHITER33GTS-T
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
