Well its probably because I took it off the dial once too often but my speedo is not working.
I have pulled the pickup out of the gearbox and replaced it but still no go.
I have removed the dash and when I drive the little plastic thing that goes into the back of the dash still spins and also spins under load (me pushing my finger onto it)
I have no idea what is wrong with it can anyone shed some light on this problem. Has anyone else had the same problem?
BACKGROUND
"When I was at the drags the other night I did a burnout and got a lot of axel tramp, it was very violent and shook the entire car. After that the speedo didn't work and my HICAS light came on and I lost my power steering."
https://www.sau.com.au/forums/topic/1048-speedo-no-go-help-please/
Check if you can pull the tip of the speedo cable (that goes into the instrument cluster) out of the sheathing - that means its broken, and needs to be replaced.
I broke mine once when putting the instruments back in. It work for a while, but eventually gave up.
OK, what I can do is when I remove the speedo console I can also remove the plastic bit inside the end of the sppedo cable. There is a small square plastic bit (like a match stick) and another plastic bit the this fits inside and a spring.....Should all of this be able to come out? If not, what do I need to fix it and where did you get yours from.
Thanks Cam
Originally posted by BOOSTMEISTER
Which bit did you have to replace?
The whole cable.
I tried getting a new inner from the local instrument shop, but they are a sealed unit - only way to replace is with another cable.
Thanks blind_elk I will see how the ereplacement cable goes from Japtaxi, hopefully it will fix the problem.....I imagein it is going to be a nightmare to install...
So, next problem, my HICAS light comes on after about 5 minutes of driving and I loose my power steering, sometimes it happens in the reverse order....I can't find the fuse for HICAS does anyone know where it is? or what could be causing this
Recon it will be related to your non-working speedo...HICAS needs vehicle speed to work, so I'm guessing it throws up an error. I'd sit tight until the speedo is working again, and then if it plays up still, try a diagnostic on the HICAS or visit a friendly Nissan dealer with a Consult unit...(though normally they look like donald duck with dollar signs for eyes when you say the magic words "could you plug your consult unit into my car please?")
Cheers,
GW
replacement cable? I thought you were after the speedo instrument ... doh sorry I'v only got the instrument not the speedo sensor+cable etc.. :D Let me know if you want the speedo instrument as I'm getting lost in all these jargons ... :(
  • 3 months later...
Hi guys,
My speedo just died today. Needle not moving, and the numbers are not running. The revs meter still works though. Then after about 5 mins of driving, the HICAS light turns on and the steering wheel becomes stiffer. Sometimes, steering wheel gets stiff then HICAS light turns on.
You guys reckon it's the same problem mentioned in the previous postings?
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
