So the rest of us can dream Munro , and think of what might be.
The terbs would be good but the rest of the engine to do them justice is what's gonna cost.
Free Bump
Cheers
Ken
https://www.sau.com.au/forums/topic/10484-hks-2835r-turbos/#findComment-171067
Fair comment gtrken.
What - 3 GTRs now?
I take it you'll get rid of the WRx now?
The thing that suprises me (at least in Adelaide) is the lack of mid
range performance GTRs. We have a few sick ones & lots of stockies.Where are all the 11 & 12 second GTRs???
I'm sure there are heaps of them interstate.
https://www.sau.com.au/forums/topic/10484-hks-2835r-turbos/#findComment-171079
I think you will find he did it on Nitto Jap street rubber.
3 x GTR's but have to get rid of a couple to cash up.
The rex is used for our Rally courses ( best place for them )
And I think those 2835's would be overkill on anything less than a 2.8 litre GTR with a lot of work.
But , if I sell a couple of R's .........
Cheers
Ken
https://www.sau.com.au/forums/topic/10484-hks-2835r-turbos/#findComment-171107
9.66 on Nittos. 3litre OS engine.
Each 2835R is rated at 420 hp.Perfect for single on SR20.
HKS 2540s are perfect for 700hp(rated at 350hp each) & still low mount.
GTRken - sell em,sell em, & go crazy on one.
sorry ndr.
I am trying to sell them - not start a discussion!
PS. IF I DO sell them - 3037S x2 will be next step up.
https://www.sau.com.au/forums/topic/10484-hks-2835r-turbos/#findComment-172519
  • 3 weeks later...
thanks ultim8DTM5(what does that stand for?)
I dont really understand the Jap catalog but I think the flange is
GT25.Will need external wastegate.
$3000 ea is correct.
https://www.sau.com.au/forums/topic/10484-hks-2835r-turbos/#findComment-204357
This might help clear things up for anyone wondering about trims and fitment,
http://www.hksusa.com/categories/more.asp?id=1092
Hope it helps
Steve
Munro, I am bloody amazed that these havent gone yet, they must be close to the bargain of the century - perfect singly for a 2 to 2.5L and they sell new here for over $5K each!
https://www.sau.com.au/forums/topic/10484-hks-2835r-turbos/#findComment-204568
Thats better - in English.
Yeah, 3037S turbos might have to wait.
could put TD06s on it, but would much rather run ball bearing
HKS turbos 'cause they are the ducks guts.
Runs well with the 2835Rs, so can stay as it is.
https://www.sau.com.au/forums/topic/10484-hks-2835r-turbos/#findComment-205824
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
